Results 16 to 27 of 27
Thread: Auxiliary lights that don't empty the wallet suggestions
    Ash Grove, MO
    Quote Originally Posted by josh00 View Post
    When I bought my 02RT it had the small PIAA lights and liked them alot, But one burned out last year so this winter I went real cheap. I went to Walmart and got a set that looks almost the same fot $20 bucks. I hooked them up a couple a weeks ago and they are real bright. I have not road at night with them yet, but my main reason for them was so people would see me in the day and I think they will work just fine for that. And for $20 dollars I thought if I don't like them I'm not out much. And I will go with a higher dollar set, but I think that I'm going to like them.
    +1! I have a cheap set on my bike, 55 watt h3 bulbs. Replacement bulb is like 4 bucks. I use them in the daylight to be seen, but they are plenty bright for night time too, which is why I don't use them at night. I find that the reflected light from the road is very distracting, so I use them only for city driving at night, when the ambient city light is high and turn them off when out of town. But I use them all the time in daylight.
    Mike Davis
    1985 K100RT
    1998 R1100RT
    Registered User JohnM's Avatar
    Da Joisey Shore
    If you Google "Pilot Driving Lights", you'll come up with some inexpensive options.
    I had the PL-1010C models (PIAA clones) installed on my K75's fork legs w/ the Martin Fabrication mounts. Did a decent job.
  3. 02-19-2012, 01:56 PM
    Reason
    lacks clarity
  4. #18
    the Wizard of Oz 26667's Avatar
    Jul 2006
    NW suburban chgo
    Quote Originally Posted by TomBarnhart View Post
    Hella ff50, good lights, good price
    and you can, with a bit of labor and ingenuity mount them to the brake caliper housing(?) using $3 "L"brackets from home depot. There are pix somewhere on the forum. maybe oilheads. works for me.
    We might as well walk. ~ Adam Guettel The Light In The Piazza
    used to own: 1982 R100T, 1984 R65, 1986K75C, 1997 R1100RT, R850R, K75S, 1978 R100RS... what was I thinking?
  5. #19
    Astatula, FL
    LED lights
    My recent addition to the rig. ADVMonster LED's on the bike forks and one in the hack. Not giving up the FF50's on the fairing.
    Mount made with aluminum, bent in the vice. Chrome spacers from ACE hardware in the bolt recess in the fork legs:
    Bob Weis
    '04 K12RS - Hannigan Hack
  6. #20
    Astatula, FL
    Front view, Hack LED at full power, fork LED's dimmed:
    Bob Weis
  7. #21
    Motorcycleton
    My first LED aux lights were the VisionX Solstice Solo lights as shown in the link below - the seller offers a discount (see ADV vendor page for more info). These lights were easy to mount, are highly visible (to oncoming traffic), and provide decent illumination -
    http://www.visionxstore.com/Motorcyc...ghts/XIL-S1103
    Next I became interested in the less expensive LED lights from ADV Monster - I have several of the 3 LED and 4 LED flavors. These were also pretty easy to install and are pretty durable - there are some pretty good write-ups about testing of these lights on ADV under LED Aux Lights -
    http://advrider.com/forums/showthread.php?t=607184
    http://stores.intuitwebsites.com/hst...Categories.bok
    Similar LED lights to those sold by ADV Monster can be found at 24x7DIY. The cost seems a bit lower, but the lights come directly from China and there is less support than offered by the ADV Monster vendor -
    http://24x7diy.com/index.php/cPath/23
    The least expensive option that I've found are LEDs from PlasmaLEDs. The power is lower and thus these lights would not really serve for nighttime illumination. However, the LEDs are really bright and very noticeable to oncoming traffic. The 008 LEDs are water proof -
    http://www.plasmaled.com/high_power_module.htm
  8. #22
    Registered User SeabeckS's Avatar
    Oct 2005
    GPS (Greater Puget Sound)
    Quote Originally Posted by 26667 View Post
    Uh, shelf brackets to mount a piece of wood on the wall? Well...maybe. (NOT)
    With the amount of shock and vibration from being mounted on a front wheel/fork assembly I'd be checking that "mount" for metal fatigue frequently. Like hourly at least. The FF's for example are fairly light, but the flex from even a small mass like that on a $1.49 bracket isn't something I'd want attached to my brake caliper bolts.
    Just saying that I think I'd look for some better metal than a bracket that was forged out of the cheapest possible materials in a Chinese factory...YMMV.
    Cheers!
    Bill Johnston
  9. #23
    Astatula, FL
    Quote Originally Posted by SeabeckS View Post
    Cheers!
    C'mon Bill, we all know what the cheapest thing on a BMW is............
    Bob Weis
  10. #24
    Proud Veteran SteveAikens's Avatar
    Clovis, NM
    When I bought my 02RT it had the small PIAA lights and liked them alot, But one burned out last year so this winter I went real cheap..
    If they are the same 'small PIAA Lights' that are the 1200 or 1100x, you can slip over ot Lowes and pick up a couple Sylvania MR-16 bulb of your choice and they are a perfect fit to the housings. The MR-16s are for track-lighting - or your occasional burnt out PIAA lights.....
    Nom de Plume:
    Steve Aikens, Clovis, NM
    BMW MOA #6218
    IBA# 442
  11. #25
    Oct 2005
    Quote Originally Posted by Bobmws View Post
    Bill Johnston
  12. #26
    Dec 2011
    East Troy, WI
    It amazes me that I can't find some micro can style single LED easily mountable lights under $50. 300 lumens maybe?
    All I'm looking to light up is the shadow underneath the headlights to make going down a long dark driveway a bit easier.
    I'm tempted to get a couple of 12v rechargeable flashlights and wire them up.
  13. #27
    Motorcycleton
    Quote Originally Posted by WisconsinKris View Post
    All I'm looking to light up is the shadow underneath the headlights to make going down a long dark driveway a bit easier...
    Perhaps you should take a look at these - specifically the 008 -
