Results 1 to 15 of 28
Thread: Auxiliary lights that don't empty the wallet suggestions
Hybrid View
    Dec 2011
    East Troy, WI
    I have a 2005 f650cs
    I am looking for auxilary lights that won't break the bank. I'm not looking to light up a trail just enhance the ability for oncoming cars to see me as well as light up the first 30 feet immmediatly in front of the tire in front of me while pulling into the driveway and garage.
    Anyone gone a cheap way successfully?
    Oh oh, you may not have titled and put this post in the proper place. You may be scolded and moved!
    I am the .45% DBCasey's Avatar
    Sep 2010
    Frankfort, Kentucky
    Prepare to be moved to Gear once the Mod Gods get wind..
    good question though. Most Aux light systems must be made out of unobtanium by what they cost.
    Isn't that what Captain America's shield was made out of?
    DC
    Thank a teacher if you can read this, thank a veteran that it's in English.
    D.B.Casey-MSF#133889
    2011 RT
    Port St. Lucie, FL
    Hella ff50, good lights, good price
    Astatula, FL
    Quote Originally Posted by TomBarnhart View Post
    +1 on the Hella FF50. Great light, plastic body with a quality casr reflector/sealed lens, H7 bulb. Last I looked you can find them for $100 or less. Full kit with relay, wiring harness and switch.
    Bob Weis
    '04 K12RS - Hannigan Hack
    Feb 2006
    Austin, Texas
    Another vote for Hella FF50's.
    2015 R1200GS Adventure
    the Wizard of Oz 26667's Avatar
    Jul 2006
    NW suburban chgo
    and you can, with a bit of labor and ingenuity mount them to the brake caliper housing(?) using $3 "L"brackets from home depot. There are pix somewhere on the forum. maybe oilheads. works for me.
    We might as well walk. ~ Adam Guettel The Light In The Piazza
    used to own: 1982 R100T, 1984 R65, 1986K75C, 1997 R1100RT, R850R, K75S, 1978 R100RS... what was I thinking?
    Astatula, FL
    LED lights
    My recent addition to the rig. ADVMonster LED's on the bike forks and one in the hack. Not giving up the FF50's on the fairing.
    Mount made with aluminum, bent in the vice. Chrome spacers from ACE hardware in the bolt recess in the fork legs:
    Bob Weis
    Registered User SeabeckS's Avatar
    Oct 2005
    GPS (Greater Puget Sound)
    Quote Originally Posted by 26667 View Post
    Uh, shelf brackets to mount a piece of wood on the wall? Well...maybe. (NOT)
    With the amount of shock and vibration from being mounted on a front wheel/fork assembly I'd be checking that "mount" for metal fatigue frequently. Like hourly at least. The FF's for example are fairly light, but the flex from even a small mass like that on a $1.49 bracket isn't something I'd want attached to my brake caliper bolts.
    Just saying that I think I'd look for some better metal than a bracket that was forged out of the cheapest possible materials in a Chinese factory...YMMV.
    Cheers!
    Bill Johnston
    Payson, AZ
    Quote Originally Posted by WisconsinKris View Post
    I went with these on my 2003 CS with the remote.
    The Model 60
    http://stores.intuitwebsites.com/hst...off/Detail.bok
    Wide Beam
    3600 lumens
    Cree XM-L T6 LEDs
    2.4 amps (28 watts) @12v
    aluminum housing
    Length: 70mm , Diameter 55mm
    Black durable coating
    o-ring sealed housing
    one meter wire lead
    includes flat mount mounting option - (stainless)
    shatter resistant lens
    a special introductory price for ADVR inmates which will be good through the end of February. Simply enter the code m60sale into the promo code box and save $20 on the Model 60.
    Oct 2005
    +3 on the FF50's.
    Got a set of foglight FF50's from Susquehanna Motorsports for the R1150R I had a few years ago, and put a set on my R11S last year.
    With the fog lenses I found they had such a sharp upper cutoff line that I could just leave them on all the time. Put a ton of light on the road close to the bike and projected down the road and to the side very nicely to...
    Good luck..
    Bill Johnston
    Braintree, MA
    B R I G H T LEDs, cheap prices: ADV Monster
    -Tom (KA1TOX)
    Registered User RapidRoadRescue's Avatar
    Feb 2012
    Indian Creek, IL 60061 (AKA Vernon Hills, IL)
    +1^^^
    The guy who invented the first wheel was an idiot. Now, the guy who invented the second wheel... he was the genius.
    www.motorcycleworkshop.net
    www.rapidroadrescue.com
    Jul 2007
    THE BIG SKY
    Search eBay for LED marker lights. They draw little power and provide no illumination, but are visable in the day and nite. I had a set on my GSPD for a year or two. Cost me $12.50 for a set. No switch, but they used so little current that I wired them to a switched circuit so they came on with the ignition.
    Here is an example of what you can find ($21.00). Play with the words you use to search.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
  15. 02-19-2012, 01:56 PM
    Reason
    lacks clarity
