Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 34
Thread: Sea foam in Beemers
    DUCMONZA
    Smile Sea foam in Beemers
    Has anyone ever used Sea foam in their bikes? I've used it for years in all of my marine equipment and yard equipment. I've been afraid to try it in an F.I. System, but on my old CB750 the stuff works miracles.
    Just curious to see what other members think about using the stuff.
    Sheboygan, WI
    Smile
    Been using it in the R1200RT since '06.
    No problems - good stuff!
    Clovis, NM
    All the time. Keep the injectors clean and burns what's in the tank. Won't hurt a thing.
    Nom de Plume:
    Steve Aikens, Clovis, NM
    BMW MOA #6218
    IBA# 442
    Raspberry waffles Bob!!! kewlmoose's Avatar
    Jan 2007
    SE Wisconsin
    Used it in my R65 & in my R1150, works great!
    82 R65LS - gone but not forgotten
    02 R1150RT
    "Oh good, my dog found the chainsaw"
    "I finally got my head together, now my body is falling apart."
    Jun 2005
    Green Bay, WI
    I've used Seafoam and Chevron Techron. No problems with either. Now I stick with Techron though because I feel it is more effective and I have a test report of the most common fuel cleaners, and Techron was proved as the only real effective cleaner with no harmful after effects.
    Registered User tourunigo's Avatar
    Aug 2005
    Larry's River, Nova Scotia, Canada
    Had a buddy's K1100LT for a bit while I was tinkering on mine. Double yer pleasure. Put Seafoam in mine and equal in his.... gave them both a backyard highrev tuneup. Gave him back his bike and he said, "wow, what the hell did you do to it? Like a new bike" Of course I lied and said that it had a lot to do with my tuneup abilities ..... and, at no charge. Is that ethical? - Bob
    Bob Weber
    saltyfogriders@gmail.com
    Larry's River, Nova Scotia, CANADA
    Luddite Looney wecm31's Avatar
    Jun 2009
    Eganville, Ontario
    I had heard that repeated use isn't oil friendly....I was told to consider a dose at the end of the riding season to clean out the fuel system and then change the oil.
    thoughts??
    Gerald P
    The last thing I want to be is just like everyone else...
    1985 R80RT
    1969 Sport Fury Convertible
    Quote Originally Posted by wecm31 View Post
    thoughts??
    Sure. Either will dissolve gums and loosen carbon in the combustion chamber. The carbon bits are hard and can wind up in the oil. Good practice is to dose a tank of fuel just prior to an oil change and to then drain any of the contaminants away with a fresh oil change.
    But, if I had symptoms of a clogged injector while on the road I would dose the fuel and rely on the oil filter to catch any carbon particles. But prefer to change oil afterwards if possible.
    Jun 2011
    Piedmont area of NC.
    I'm in with Paul on this one.
    I add some Seafoam to the tank just before I do an oil change on my airhead.
    Registered User AKsuited's Avatar
    Jul 2009
    Southern Tier of New York
    I'll have to look around and see if any is available.
    FAQ's:
    http://www.seafoamsales.com/gasoline-engine-faqs.html
    Harry
    Clovis, NM
    It would help to know where you're located Harry.
    However, NAPA Auto Parts carries it.
    Nom de Plume:
    BMW MOA #6218
    IBA# 442
    Registered User Bohan's Avatar
    Oct 2008
    Georgia - USA
    Unlike Chevron Techron, Seafoam can be added directly to the oil according to the instructions on the bottle. Are there any advantages/disadvantages to doing that?
    thanks
    2004 BMW R1150RT
    Registered User boxerkuh's Avatar
    Carolina's
    I am with Paul on this one... I add Chevron Techron in my Airheads prior to changing the oil. I have had not had any problems with it.
    Keep the rubber side down!!
    1986 R 80 RS
    1992 R 100 R
    BMW MOA Life member; Ironbutt Member; Airhead Member
    Bluenoser
    Mar 2010
    Lethbridge Alberta
    Quote Originally Posted by Bohan View Post
    thanks
    It will act like a solvent in the oil and will clean things up. Not always a good idea on an older engine. I'm not sure of a situation that I'd be putting it in the oil.
    If memory serves me correct you put a measured amount in the oil ( subsituting sea foam for some oil ) and run the engine for about 100 miles and then dump the oil.
    The suff works really well in the gas as a storage add or to just clean up the fuel system. Works wonders on old carbs.
    1999 R1100s
    1999 GL1500
    Left Coast Rider
    Nov 2011
    I've never been a big fan of adding a fuel conditioner/combustion chamber cleaner/carb cleaner to a lubrication system.
    I mean, our oils are detergent, are they not? If one properly maintains their bike, how dirty can the inside of a motor be? Every engine I've had the pleasure of disassembling has been as clean as a whistle.
    I will await those with greater knowledge to tell me how far out in left field I am (or not).
