Results 1 to 15 of 24
Thread: Original BMW Tool Kit
    Registered User dgarber's Avatar
    Dec 2011
    Metamora, IL
    Just received my first street bike. It's a 1974 BMW R90/6 with 18,000 miles. Still snow on the ground here in IL, so I have to find something to do with myself other than walking around the bike constantly. It came with the original tool bag, grease rag, and a bunch of assorted tools. What I'm looking for is a picture of what the complete tool set would look like for this year and model of bike. If anyone can help me out with a pic or a list, I would greatly appreciate it. Thanks.
    Doug
    Administrator 20774's Avatar
    Doug -
    Welcome and congrats on the bike! Duane has some pictures of original tool kits and other information here:
    http://w6rec.com/duane/bmw/toolkit/index.htm
    Mar 2008
    DeLand Florida
    Not sure this will help, but this is from my 78. Having also owned a 74 R90S I can tell you that it is about the same as that bike's tool kit. My kit also has a few extras, but I think all the factory tools are there.
    Registered User 88bmwjeff's Avatar
    Aug 2004
    Walnut Creek, CA
    The parts fiche list all the tools that come in the kit. Click on the link below, then go to equipment parts to get to the tool kit.
    http://www.maxbmwmotorcycles.com/fic...9&rnd=03252011
    Jeff in W.C.
    1988 R100 RT (the other woman)
    "I got my motorcycle jacket but I'm walking all the time." Joe Strummer
    Dec 2011
    Metamora, IL
    Quote Originally Posted by 88bmwJeff View Post
    Thanks!
    Doug
    Registered User PHMARVIN's Avatar
    Oct 2003
    El Paso, TX
    Hi,
    Look at message 3. The extras I see are the adjustable wrench, the thin shock wrench (probably for Koni shocks) and the long tire pressure gauge. The stock gauge was only 3 or 4 inches long. Missing are the feeler gauge (including the one which fits the master cylinder to make sure the free play is correct - it is U-shaped with, I think, 4 normal feeler gauges attached to it) and the rag with BMW woven into it.
    Ride Safe,
    Phil Marvin - El Paso, TX
    '94 K75A/3
    '95 K75RTP
    Pismo Beach, CA
    Missing are the feeler gauge (including the one which fits the master cylinder to make sure the free play is correct - it is U-shaped with, I think, 4 normal feeler gauges attached to it) and the rag with BMW woven into.
    ... and pliers, as seen below.
    From Duane's website; R80GS and R80ST tool kit (but the pliers are the same (at least they are the same ones in my '73 R75/5 tool roll!))
    Of course, unless you intend to "show" and want a "period correct" tool roll, what matters is having the tools you need, when you need them.
    Like... the Northwoods points adjusting "set" that I carry now.
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    Atomic City Boxer 154048's Avatar
    Nov 2009
    Santa Fe, NM
    Lew, tell us more about that Northwoods set....
    Steve in Santa Fe
    1980 R100RT
    96' Triumph Trophy
    Northern Front Range, CO
    copy of something sold years ago for easy setting of points. remove orginal lobed centrifugal advance, replace with this one (entire OD is same as high point of stock lobed unit), adjust points with feeler gauge, remove, reinstall cetrifugal. it lets you set the points without having to contend with the 2 centrifugal arms getting in the way..
    Ride Safe, Ride Lots
    Pismo Beach, CA
    ... now if someone would come up with a Quick Disconnect Front-Fork doing the whole points thing would be cake.
    Or maybe I should finally break down and buy a lift.. .
    Lew Morris
    1963 Dnepr
    Points adjusting tool
    pcarfan
    Just got my 83 R100 and need the tool kit. Besides the flea market section is there somewhere else I can find one? I recall seeing some new ones being sold for about $140, can't remember where at the moment but are they the same?
    Registered User amiles's Avatar
    Jul 2003
    Murrells Inlet, S. C.
    I don't know about anything else in the kit, but since the 1974 axles are smaller than on later models the wrench that fits the main bolt might be a different size.
    Pismo Beach, CA
    Two sets on eBay today, plus one "aftermarket" kit.
    Might want to keep your eye on this one... http://www.ebay.com/itm/70s-BMW-R60-...item3f13298eed
    Lew Morris
    1963 Dnepr
    pcarfan
    Quote Originally Posted by Lmo1131 View Post
    Thank you!
    Is there a difference in pouch and edging colors for different generations or years, I've seen a lot of variations? I'm trying to buy as close to what would have come with the bike.
