Results 16 to 20 of 20
Thread: 1985 K100 Monkey nuts
    Apr 2005
    Rapid City South Dakota
    almost final
    Let‘«÷s tie a knot in this thread. At least for the time. I will be ordering parts from my local dealer. The dealer dilemma is that it is not really local and doesn‘«÷t do internet parts. The aftermarket is really faster even though time was not a factor in this case. If time were a factor I would modify the parts in a heart beat. If it were an emergency I would make them work. It seems from your responses the BMW dealer will supply the kind that need a little ‘«£glue‘«ō to stay in during assembly not the kind that need to be forced. I will let you all know when get the Alternator Drive Cushions Over and Out Harold in Kansas
    Harold In Rapid City, SD
    1985 K100RT Bullit
    1985 K100XX/EML Bemel
    Apr 2005
    I am fast becoming the worlds expert on alternator driver cushions, AKA gobbers and monkey nuts. I recieved the gennie parts from a dealer. They were the 5 sided shape that I expected but they were slightly larger then the older ones. In fact they fit into the pockets with enough friction that no "sticky" was needed to keep them in place. It took a considerable knock on the bench to dislodge them. It also took a drop or two of liquid soap to get them to slid together. In the comparison picture the gennies are on the top and the optical illusion is in play but the aftermarkets are a little longer. Any further questions on the topic may be refered to Harold in Kansas.
    1985 K100RT Bullit
    Belton Tx
    I found this thread while changing the NUTZ on my 91 75RT. What is the significance of the two notches in the lip of the clutch housing? I cant see what they might mate to on the engine.
    The NUTZ were not in terrible shape-some slight melting and cracking. I found that acetone does well in removing the residue left by the melted NUTZ.
    Replacement parts are on order.
    Ron
    91 K75RT ABS
    Quote Originally Posted by roncooper View Post
    They are for a BMW special spanner that holds the cup stationary so the nut can be torqued. Also helps with breaking the nut loose if you need to change the cup.
    Belton Tx
    I got my OEM BMW ones installed and the engine is quieter and smoother. The old ones weren't in terrible shape, but they caused a slight buzz at 5000+ rpm that slowly developed.
    Ron
    91 K75RT ABS
