Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
Thread: Mirror Extensions
  1. #16
    mymindsok
    Just make sure that he includes a reverse threaded nut and bolt on one side.
    Having the right mirror go floppy at 80MPH is a bit disconcerting and inless youer carrying an 10mm Socket wrench in your tank bag, you're kinda screwed.
    JAMHIK!
  2. #17
    vincent52 70816's Avatar
    Sep 2007
    grass valley, ca
    RS mirror extensions
    so guys i'm a bit late
    R100RS mirror extensions made and sold by Nick Greear is Bill or anyone thinking of/ or making RS mirror extensions??
    9/2013
    jim
  3. #18
    Diy
    Here's what I did on my RS:
    You can buy OEM mirror mounts (called "mirror base") for not much $.
    46 63 1 236 129 MIRROR BASE LEFT - BLACK $8.98
    46 63 1 236 130 MIRROR BASE RIGHT - $8.98
    I drilled out the hole that the original mirror bolted into. I then took an afteremarket stalk mounted mirror of decent quality and bolted it to the OEM mirror mount. A bit of grinding with the dremel and it looked and worked very well. I unbolted the originals (mounts and mirrors) and put them in a box, so I could go back to stock if all I want to see is my elbows.
    Theo Marks
    '74 R75/6
    '88 R100RS (gone but not forgotten)
  4. #19
    Registered User Bob_M's Avatar
    Aug 2004
    Portland Oregon
    1982 rs
    http://forums.bmwmoa.org/showthread....eferrerid=2454
    With the help of my brother-in-law I made mirror mounts for stalked Rizoma mirrors.
    It was easy, take a block of aluminum and remove all the material that is not mirror mount.
  5. #20
    Hey Theo,
    Any chance of posting a picture or two of your work?
    Thanks,George
    1977 R100S
    1978 R80/7
    1977 Triumph Bonneville
    1970 Honda CT90
  6. #21
    bike gone
    Sorry bike has been sold and is long gone. But really it was cheap and easy, and totally returnable to stock if desired.
