Results 1 to 15 of 19
Thread: Question for Mr. Voni
    Jul 2007
    THE BIG SKY
    In the recent article in ON I noticed that you changed brake fluid on average every third service. I'm figuring that equates to every 15 to 18K miles. Have I miscalculated? Is this really necessary? Are women in red particularly hard on brake fluid?
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    Quote Originally Posted by AKBeemer View Post
    I try to do it once a year - in the fall. The older bikes had that as an "annual maintenance" task. I think - I'm not sure - that on newest models BMW now says every two years, but that change might have been for coolant. Once a year is my norm.
    This link (bmwmc.net, pdf file) was just sent to me this morning by someone who had a question about brake bleeds. Short version:
    rubber brake lines: every year
    Stahlflex brake lines: every 2 years
    Ed Kilner #176066
    Nov 2011
    Mississauga, ON
    Thanks for the morning giggle. Won't be buying any of those Stahlflex self-destruct thingys anytime soon...
    Ed
    2015 R1200RT; 2011 R1200RT RIP; 2000 Triumph 900 (sold)
    http://triumphantsblog.blogspot.ca/
    Quote Originally Posted by BMW Triumphant View Post
    When do they self-destruct?
    rabid reader dbrick's Avatar
    Santa Cruz CA
    I think - I'm not sure - that on newest models BMW now days every two years, but that change might have been for coolant. Once a year is my norm.
    The 2006 edition of the BMW Motorrad R12R Maintenance Schedule shows brake fluid replacement at two year intervals:
    David Brick
    Santa Cruz CA
    2007 R1200R
    Ed Kilner #176066
    Nov 2011
    Mississauga, ON
    Apparently, after two years. Seems ridiculously short time. Seems self-serving desire to sell more products.
    All this IMHO, of course. Still, what could possibly be the reason for replacement after two years? Have never had to replace braided brake line, have you had to replace them?
    Ed
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Replace the brake fluid, not the brake lines.
    Lee
    2016 R1200RS
    MOA # 30878
    Perhaps I was a bit too succinct in my short version. How about this:
    Replace the fluid every year if you have the rubber lines.
    Replace the fluid every two years if you have the Stahlflex brake lines.
    As for self destructing... The ones the came stock on my '05 GS are still going strong. Brake line failures haven't exactly been a big issue from what I read here. I don't remember reading of any, come to think of it.
    Ed Kilner #176066
    Nov 2011
    Mississauga, ON
    Clearly, i did not read the post carefully enough. Brain seized on brake line and never considered the line supplier was recommending a fluid change interval.
    Technical reading skills need to be learned and then practiced. Seems i slipped on the latter.
    Same with technical writing. We all need to be careful in providing adequate detail to try to prevent half-asleep readers going off on an unintended direction, as i obviously did.
    Ed
    Northern Front Range, CO
    if your stock brake lines are not SS, they most definitely will self-destruct. die a slow death from old age, actually- but they certainly have a finite life span. AndyVH will likely chime in with more specifics as to process and causation- but it is a mistake to think that rubber lines will last forever.
    Ride Safe, Ride Lots
    It is also a mistake to believe that "stainless braided" brake lines will last forever. Some will fail sooner than others, depending on how they are made. Some have a rubber lining, a stiffener, and a braided outer sheath. The rubber can still fail. It won't likely pop and spew, but it can swell internally and rubber bits can slough off clogging things.
    Jul 2007
    THE BIG SKY
    OK, now I've been on a brake fluid change frenzie. Guess I've neglected this a bit. Three of five bikes done. Only the rear of Annie's thumper looked bad; sorta like day old Army coffee.
    Kevin Huddy
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    That's why, if you are going to put stainless lines on your bike, make sure they are the more rigid teflon lined style.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    Ouch!
    The appearance of weak apple juice is about as dark as I like to see it. But you didn't say chocolate syrup, at least.
