Results 1 to 15 of 15
Thread: BMW Charger
    Aug 2011
    BMW Charger
    I have one of the grey BMW battery charger. Everytime I plug it into my scoot (r1200rt), the green and the red light comes on. The red light says error. I think it's charging anyway. Have you guys seen this>
    Aug 2011
    Are you turning the ignition on first, then plugging the charger in, then turning the ignition off? The CANBUS system shuts the port down after ~30secs and that could be the cause of the error. If that is the case, the battery is not being charged.
    Technically you can plug the charger in within ~30secs of shutting it off, but I find it easier to just flip the ignition than guess if I was quick enough or not.
    Jun 2007
    Portsmouth, NH
    What year and model? My 2005 R1200GS required a odd ritual to enable charging (and would require it to resume charging after power outages), my 2011 R1200R just starts charging as soon as it is plugged in.
    Aug 2011
    I tried turning the key on first and them plugging it in but that didn't make a difference. If I start the ending, the red light goes off for a while and then comes back on. Is there a reason why I can't just put a pick tail on the battery and plug a battery tender into it? (2007 rt1200rt)
    Registered User Jim Rogers's Avatar
    May 2009
    Optimate 4 with proper pig-tail connected directly to battery. Use it for all the bikes, the generator, and the '65 Pontiac.
    Gear Up and Ride Safe
    Jim Rogers
    2010 R12GSA aka Heidi
    Yorktown, Va
    Registered User indawin's Avatar
    Jul 2009
    Plantation, Fl
    I have the BMW charger for my 1200RT. We have a lot of momentary power outages, one to five seconds, and I'm wondering if that disconnects charging through the canbus. Anyone have an idea?
    Tom
    Plantation, Fl
    Jun 2007
    Portsmouth, NH
    I suspect it depends on the year of the motorcycle. The newer ones do not require the CANBUS ritual, older bikes do. I found out about the power outage issue when the battery for my 2005 GS was DOA in the spring. The charge had been plugged in all winder, but it had obviously stopped charging at some point.
    Jun 2007
    Portsmouth, NH
    Quote Originally Posted by stokesrl View Post
    Nope. I added one to my 2005 GS and charged it that way for years.
    Feb 2010
    Westchester, N.Y.
    I think we need some more info before we can help you. What year is your motorcycle and after the initial light up, do you just see the power light on the bottom of the charger and the charge sequence across the top?
    It will re run the charge sequence again, (red to green) if it senses a drop in the battery.
    This seems to be a fairly ongoing thing, not at all like the old red, yellow and finally constant green stage of the older chargers.
    It does seem overly complicated though
    Aug 2011
    its a 2007 r1200rt. The green power light stays on. I plug it in, the red "1/3 charged light comes on also. After a few seconds, it goes off and the red "error" light comes on.
    EyeBiker
    May 2006
    Abingdon, VA
    Quote Originally Posted by jim rogers View Post
    optimate 4 with proper pig-tail connected directly to battery. Use it for all the bikes, the generator, and the '65 pontiac.
    +1, minus the generator and pontiac, but including the lawn mowers and garden tiller!
    Calvin Miller
    2012 K1600GTL
    Feb 2010
    Westchester, N.Y.
    I'm sorry I cant remember where, but this was discussed on one of the other sites either (BMW Luxury Touring, BMW SportTouring or K-Bikes) and it was a loose or reversed polarity problem to the accessory port.
    Once the leads were reversed everything worked fine, including the endless cycling!
    Aug 2011
    Ok, so if I:
    Turn on the ignition
    Plug in the charger to the bike
    Then plug the charger into the wall...
    It acts like the battery is discharged to 1/3 charged. Atleast the error light doesn't flash. Unfortunately, ater 2 days it doesn't get past 1/3 charged.
    HUmh... Good thing the bike starts fine. The battery tender says it's charged.
    Aug 2005
    SoCal
    Voltage
    Do you have a voltmeter with which you can check the voltage at different time intervals.
    I have found that some batteries may require to charge than others. After riding for say couple of hours and the plugging the charger on my original GEL battery, red and green woul come ~10 minutes and green ~45 mins. Now with Panadonic AGM, red and green would come ~1 hour and green ~1.5 hours later.
    Mar 2011
    socal
    Jim Rogers
    Has the right idea optimate 4 dual, mine has the BMW pigtail, park the bike remove key and plug it (under seat) sends a signal to CANBUS and allows it to charge/condition battery. Only negative is GPS has to be unplugged or it starts up every time charger cycles
    Both BMW dealers here carry them, as their in agreement that's it's a better product than the factory charger
