Results 1 to 11 of 11
Thread: U joint repair
    protomike64
    U joint repair
    Can the U Joints be replaced on a 75/5? Working on a bike that has been hit and damaged the u-joint. Do i need to find a new one? How do i know if its a LWB or not? I have a pic of the swing arm. Any help?
    Jun 2007
    Edmonton AB Canada
    u joint
    Just below the flange you will see where there is a short cylinder(2"+or-)spliced in which makes it a LWB.Most of the collective agree that a complete replacement of the swingarm including driveshaft is the most economical way to go-check used.If the u joint experienced enough trauma to break then the swingarm is probably compromised too.
    Russ
    Pismo Beach, CA
    No. Not exactly. But the drive shaft/u-joint assembly can be repaired. At over $600 for a new drive shaft, I had mine rebuilt for around $200.
    Read: http://forums.bmwmoa.org/showthread....hlight=u-joint
    In particular, you're looking to hook up with Henderson Precision to rebuild your driveshaft u-joint.
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    Pismo Beach, CA
    Easy... read this: http://forums.bmwmoa.org/showthread.php?t=57237
    LWB =
    Or ...
    You have a long wheel base swing arm.
    Lew Morris
    1963 Dnepr
    protomike64
    Flea market guy has a shaft. This forum is great. Best club i ever joined. The bike is cool too.
    Northern Front Range, CO
    i think i paid around $160 for new u-joint with these guys.
    http://www.machineservice.com/
    Ride Safe, Ride Lots
    Pismo Beach, CA
    ... who guys?
    Lew Morris
    1963 Dnepr
    Quote Originally Posted by Lmo1131 View Post
    ... who guys?
    what you talking 'bout?
    mymindsok
    $160 to have a U-joint replaced?
    You can buy a good used replacement drive shaft for $25! Check IBMR's flea market or Ebay!
    Pismo Beach, CA
    sorry bf... didn't see your "link".. . ..
    Lew Morris
    1963 Dnepr
    protomike64
    Swing arm
    Found one on E Bay $60 (swingarm and shaft).... Again we will see what we get.
