Results 1 to 9 of 9
Thread: Top Engine Cover
    DennyPink
    Mar 2009
    Fort Collins, CO.
    Top Engine Cover
    I recently bought a new to me 1992 R100RT and sometime in it's past, the gas cellanoid (sp?) stuff had been removed from under the top engine cover, leaving 11 holes. My question is, will all the open space cause problems with water getting into the starter and front of the engine?
    I checked several sources and new covers are sold with the holes, part # 11-14-1-337-481. If you like me, didn't like the holes, what have you done? Thanks!
    Denny Pink
    Cold Colorado
    Huckleberry, Gilera &Toad kstoo's Avatar
    Jul 2007
    Burlington WI
    Watch for a 1981 - 84 cover for sale used?
    1980 R100T (Gilera), 1982 R100RT (Toad), 1975 R60/6 (cern?ícalo)
    Adventures at the Cave
    1960R100S 1961BMWR69S's Avatar
    Mar 2009
    Crown Point IN.
    I have a 88 r100rt and a 88 r100rs. I took all that stuff off and I hve never had a problem. 1980 to 84 is a full cover with no holes. My 78 R100 cafe bike has no cover at all.
    DennyPink
    Mar 2009
    Fort Collins, CO.
    So "42611" you have had no problems with water/dirt getting through all the holes and affecting the starter or electrical connections?
    Denny Pink
    Mar 2009
    Crown Point IN.
    denny, durt and rain will get in there any way because the top is open for air . as far as water, the heat from the engine will disaipate the water. the 88 r100rt has o most 45000miles and never had a problem
    DennyPink
    Mar 2009
    Fort Collins, CO.
    Thank you "KST00 amd 46211." I won't worry about dirt and water, and in the mean time I will look for an 81 to 84 cover. Can't beat the experience and knowledge of this forum!
    Denny Pink
    Albuquerque, NM
    Motobins is good place for used parts.
    Buying from them means you'll get the "euro" top engine cover, which won't have the notches for the vacuum line crossover hose.
    I never purchased one from them, but did purchase three airbox bottom parts, the "euro" version having no holes for the air injection system--much cooler than rubber plugs.
    Kent Christensen
    21482
    Northern Front Range, CO
    Denny,
    You might want to check with Ray's Cycle or Barry M. in town. Both are likely to have used parts available (Barry probably more so). Maybe even Steve at Beemers & More. Send me a pm if you need Barry's phone #.
    Ride Safe, Ride Lots
    Registered User NavyCWO's Avatar
    Oct 2008
    East Texas
    The fuel solenoid system was removed from my RT when I got it. When I changed out the fuel lines, I took the cover to Lowes and got several metal plugs of varying sizes. Installed them and repainted the cover rattle-can black and when it dried cleaned off the BMW on the side. Looks great, and no extra water or dirt gets in.
