Results 1 to 7 of 7
Thread: 1975 R90/6 Front Caliper removal
    Registered User tjtraver's Avatar
    Dec 2003
    Westchester County, NY
    How do you remove the single front caliper on this bike ? Just remove the one vertical bolt under the hex cap ?
    Is this correct ?
    My front brake is dragging after application , so am going to rebuild the caliper and replace the hose . ( I've already rebuilt the MS which was leaking and was pretty rusty inside but cleaned up well )
    Mar 2008
    DeLand Florida
    Believe so, the caliper pivots on that bolt (actually a pin) as you apply the brakes. You will see that it is an eccentric pin that allows you to adjust the contact of the pad on the rotor. Should be a spring there if my memory serves me right. Also, when you take the pads out do not think of them wearing funny if they are tapered front to back. That is the way they are suppose to be so you have even contact and wear through their entire life.
    Administrator 20774's Avatar
    The pinch bolt for the fork legs should be the right pitch to screw up into the bottom of the eccentric bolt. Once you do that, you have something to jerk on to pull the eccentric out. Then the caliper can be removed.
    Mar 2008
    DeLand Florida
    Kurt, I never knew that, I always just probed until I go the pin out. Thanks for the tip.
    Registered User b25bsaboy's Avatar
    Aug 2010
    Calgary, AB. Canada
    Quote Originally Posted by tjtraver View Post
    Is this correct ?
    Thought I'd throw my 2 cents in. Once you have the hex nut out, put a flat blade screw driver rotate till you find as soft spot. Take a magnet, the kind that has an extended style when you loose a nut to bolt when working car/truck. Set it on the head and withdraw the pin.
    Rick MacPherson
    Success is Not a Destination, But a Journey.
    Accredited Motorcycle Appraiser
    1968 BSA Starfire, 1976 BMW R75/6, 1992 R100RT, 2009 R1200RT
    Check your manual, or this site, for intstructions on aligning the brake pads with the eccentric bolt. If you haven't done that, it may alleviate the dragging.
    61 Gold Star, '13 690 Duke, '13 Daytona 675R, '14 Street Triple R (gone but not forgotten: '76 R75/6, '84 R100, '76 R90S)
    Dec 2003
    Thanks !
    Thank you all for your information . I now understand how the mechanism works to be able to take it apart . This will be a good winter project . Much appreciated .
    Todd
