Results 1 to 10 of 10
Thread: Black paint on R65 engine?
    Philly
    Hi, Hopefully this is an easy one - I'm cleaning up my R65LS engine, and I will be putting fresh black paint on the airbox, starter cover and timing chain cover. Should this be a gloss black or a flat/matte black? Thanks!
    Pismo Beach, CA
    I'd split the difference and go with a "semi-gloss" ... "flat" black is a total PITA to keep clean.
    Semi-gloss is also closer to the finish on the valve covers, engine plate dropouts, and the plastic components.
    Lew Morris
    1973 R75/5 - original owner
    Mike V. #30064 30064's Avatar
    May 2006
    San Diego, CA
    Agree with Lew. I used Krylon Semi-Gloss High Heat BBQ paint on my R65 timing chest and it turned out great. Gives a very nice look. Be sure to prep the surfaces very well, clean of any residue, oils or dirt. For the valve covers, air box, and top cover, I powder coated. Links below...
    http://tinyurl.com/6q67p37
    http://tinyurl.com/822wpjo
    Mike V. / San Diego
    MOA#30064 / ABC#11027
    78 R100/7 [orig. owner] / 81 R65 [restored]
    ABC-MOA-AMA-VBMWMO / http://tinyurl.com/4df7hgs
    Pismo Beach, CA
    Nice Mike. Not only nice, very nice! COuldn't figure out what the "dashed blue" detail between the front cover fins were ... graphics tape?
    Wish I had been clever enough to wrap my frame with foam sheet....
    Lew Morris
    May 2006
    San Diego, CA
    Lew,
    I was wondering when someone was going to ask what the tape was. You are correct, it's old 1/8" wide architectural drafting tape I had laying around my office along with the rapidiograph (leroy) pens gathering dust. It fit the ribs perfectly and took an easy quick clean-up with sanding block and scotchbrite pads to dress the corners.
    Mike V. / San Diego
    Mike V. / San Diego
    Pismo Beach, CA
    Sounds like parallel universes brother ... Kohinoor pens and ultrasonic cleaner, ellipse and circle templates, triangles, T-squares, compasses and dividers, eraser shields, electric erasers, X-acto knives, dry cleaning pads, I still have three or four old Vemco machines gathering dust down at the shop.
    Like anyone uses that stuff anymore.
    Lew Morris
    ABC,AMA(LIFE),MOA,RA,IBMW MANICMECHANIC's Avatar
    May 2003
    Manitowoc, Wisconsin
    Egad, I think I also have a few broadpens and India ink from when I did freehand.
    F.O.G.Rider, Rounder #6,
    Ambassador
    BMWRA Wisconsin Region Rep
    MOA Biergarten co-chair
    Sep 2003
    Virginia Beach
    You are bringing back memories...I started out as a technical illustrator.
    Pismo Beach, CA
    A big chunk of my bread and butter for a long time.
    Lew Morris
    Registered User helmut_head's Avatar
    Feb 2011
    Michitucky
    Quote Originally Posted by Lmo1131 View Post
    Ahhh. The French curves too.
    Helmut always wears a Helmet.
