Results 1 to 6 of 6
Thread: Turn Signal Relay
    DennyPink
    Mar 2009
    Fort Collins, CO.
    Turn Signal Relay
    Turn signal relay under the gas tank is going bad. I believe the part number is 61-31-1-244-392, about $45.00. Anyone have experience with a BMW car dealer having this part, or an auto parts store? If an auto parts store which ones, and what was their part number? Thanks!
    Denny Pink
    1992 R100RT
    blah blah blah squiffynimrod's Avatar
    Dec 2008
    Regina SK Canada
    Cut & paste from ADVrider:
    "As a reminder, the pricey OEM turn signal flasher on the old airheads like my /7 can be swapped out for a "Tridon Stant" 12 volt 3 terminal #550 thermal flasher available for under $5 from any auto parts store.
    The new flasher will have a "P" an "L" and an "X"...you want to plug the wires from the new socket into the existing flasher socket...match the "P" to the black/white wire (your dash light indicator)...match the "L" to the green/yellow wire (the "load"...i.e. the turn signals)...and, the "X" to the green/black wire (+12V supply). The fourth prong (that the new flasher won't have) is brown...for ground...the new flasher doesn't need a ground.
    Thanks guys, I did this on my R80 last night and it works perfectly. I rigged up very short pig tails with male spades on one end and female on the other to patch the Tridon into the OEM connector and then zip tied it to the OEM bracket in the headlight bucket. Flashes the signals correctly AND works the dash light. So simple and cheap, makes you wonder what BMW was thinking ."
    No pithy comments available at this time.
    Please check back later.
    Mar 2010
    Vancouver, B.C. Canada
    Quote Originally Posted by squiffynimrod View Post
    Probably back then they were thinking that the Bosch relay would last for 19 years in a motorcycle environment. Pretty good life cycle.
    But $45 for a relay is pretty steep.
    Some relay trivia:
    TYCO / Siemens Electronics purchased the Bosch Relay Division. Bosch no longer manufactures relays; they are all made by Tyco and private labeled for Bosch by Tyco in the same factory in Portugal that Bosch used to own.
    Grammarian no, Rider yes ISAMEMON's Avatar
    Jun 2006
    Kings Valley Oregon
    [QUOTE=squiffynimrod;727181]Cut & paste from ADVrider:
    thnaks for this tip, it will be another one I print for my notebook of info and tricks
    Registered User alphashifter's Avatar
    Nov 2011
    Front Range of Colorado
    Good stuff! Did this yesterday & works like a champ.
    Thanks!
    Administrator 20774's Avatar
    Should be some helpful relay info here, too:
    http://www.airheads.org/content/view/159/98/
