Page 4 of 4 FirstFirst ... 2 3 4
Results 46 to 55 of 55
Thread: Shoei Multitec helmet
  1. #46
    Dec 2011
    SW Missouri
    Quote Originally Posted by jjlawrence View Post
    Zoomzoommo, thanks a lot for posting the pictures of your Neotec with the Sena. This gives me a great look to work with. Did you have any issue pushing the mount into the helmet between the outer shell and core lining? Looks like you didn't have any issue with the visor lever either. I may look into the Sena plate with the detached mic. It gives you a little more room to work plus I may be able to install the mic in between the check pad.
    JL
    No issues at all with the mount between the two pieces when the cheek pads are removed, although reinstallation on the Sena side was tight.
    12 R1200RT, 12 Street Triple R, 08 Tiger 1050
  2. #47
    Enjoy the Ride jjlawrence's Avatar
    Minnesota
    One other question
    Zoomzoommo,
    Did you have to remove the chin cold weather guard from the front of the helmet or does it slide freely over the mic when you open/close the lid?
    JL
  3. #48
    Registered User Woodbutcher's Avatar
    May 2010
    Austin, TX
    +1 on the thanks for posting the photos. Looks like you used the clamp on the mount, right? Not the adhesive backed plate.
    Looks good. I'll be ordering yet another mount I guess. Two Senas, 4 helmets, 2 heads. I'm very lucky that my wife's head is so similar to mine. We each have a primary helmet, I have a dual sport, and now my old Nolan if she wants to wear a modular instead of her Qwest.
    Rusty
    Austin, TX
    Two Wheeled Texans
    2009 R1200GSA 2013 K1600GT
  4. #49
    Tourmeister gr8ridn2's Avatar
    Jun 2009
    Kern Valley CA
    I used the adhesive mount from the Sena on my Neotec helmet with no issues so far. It has been on several 500 mile rides so far. I use the same Sena unit for either my Arai Vector or the Shoei. The gap was very tight between the shell and liner on the Neotec so I chose the adhesive mount. I didn't want to mess up the fit. The extra mount purchased included the clamp and adhesive system. The key is to use rubbing alcohol on the finish where the adhesive goes to remove any oils or wax. After that let the adhesive cure before riding. I let my helmet cure for 24 hours.
    The mounting location for my installation is the same as Zoom shows. The standard mic reaches and access for the solar shield slider is good. No problem with the mic with the chin curtain. All one has to do is reach past the curtain after the chin bar is closed to get optimal positioning.
    2014 R1200 GSA W
    2016 S1000XR
    Riding is the art of throwing yourself at the ground and missing
  5. #50
    Dec 2011
    SW Missouri
    Zoomzoommo,
    JL
    Gr8ridin's response above is perfect, but you do have to position the mic when opening or closing the face.
  6. #51
    Registered User rapz's Avatar
    Nov 2003
    Mission, TX
    I had a Nolan and it kept sliding down on my face after a few hundred miles pressing on my sun glasses so I tried the Shoei and never looked back. It's lighter and just fits my head better. I like it!
    Website: www.airheadmoto.com
    IBA No. 58411
    Current Bike 1979 BMW 100RT; 2013 BMW R1200RT 90th Anniversary Edition; 2008 Harley Davidson Ultra Classic 105th Anniversary Edition
  7. #52
    Registered User coalminer's Avatar
    Jul 2008
    St. Francisville, LA
    Quote Originally Posted by WoodButcher View Post
    I just installed the Sena on mine and my wife's Neotecs. I used the clamp on mount as well and experienced no problems. I mounted mine in exactly the same place as shown in the pictures. I also decided to use the detached boom mike after trying the attached mike and having to move it in and out of the way when opening the shield. The detached mike installed easily behind the cheekpads and so far is working perfect.
  8. #53
    Minnesota
    Sena SMH10 on Shoei Neotec
    I completed the install of the Sena SMH10 on my Shoei Neotec. I decided to use the metal backplate. I was successful finding a location to slip the backplate into the helment without any issues. I am installing the headset with the detachable mic. I installed the mic under the left check pad and it fits perfect. Needs a little bending to get around the check pad snaps. I paired up a bluetooth transmitter from my ipod and paired up just the phone with my iphone 4s. Incoming calls ring in my headset and silence the music from my ipod. I can make and receive calls.
    Everything works great inside the house but the next test will be on the bike. I will post an update of my experience.
    JL
  9. #54
    May 2006
    grove city,pa
    I used to wear Shoei helmets. Headaches and a big red dot on my forehead. Is there any improvement on this issue with the Multitec. Wear the long oval Arai now but would like a flip front.
  10. #55
    Nov 2011
    Central FLA!
    Quote Originally Posted by 66113 View Post
    I owned the Multitec and had the exact problem that you described so I tried the new Neotec and it appears Shoei has made no changes to the interior shape of the helmet. I only tried the Neotec on at the store, literally walked around the store with it on my head for about 30 minutes as I shopped for other stuff. I could still feel the same pressure as the Multitec. So if you have the long oval shaped head Arai is still your best bet. I recently bought an Arai Signet Q which I am extremely happy with. I really wanted a modular helmet but could not find one that fit my oval shaped head.
    Eric
    2011 R1200 RT (1st Beemer)
    "Hey guys, watch this!"
