Results 1 to 7 of 7
Thread: Which K75S bars for an RS
    Sep 2011
    Western Colorado
    got a quick question on the K75S bars do you want to get the heated bar version or the non heated bars I looked up the part # and they are different and also the shape is different I also found out that the early K100RS heated bars are the same part # as the 75S's heated bars which bars do I get thanks for all your help
    Registered User boxerkuh's Avatar
    Carolina's
    You may want to post this with the K bike forum???
    Keep the rubber side down!!
    1986 R 80 RS
    1992 R 100 R
    BMW MOA Life member; Ironbutt Member; Airhead Member
    I thought this was a question about using K bars on an Airhead. If that's not the case, then this definitely needs to move.
    Dec 2007
    Reno, NV
    I have the nonheated kind on my RS
    Sep 2011
    Western Colorado
    oops sorry yes I would like to try a set of K75s bars on my 77RS
    I have the heated ones. Did not know they were different shape.
    AFAIK the only difference between heated and non heated is the 3/8" hole drilled in the center section that allows the wires to enter the bars.
    But there are two different width K75S bars.
    See: http://forums.bmwmoa.org/showthread.php?t=56355
