Page 4 of 6 FirstFirst ... 2 3 4 5 6 LastLast
Results 46 to 60 of 79
Thread: centerstand vs kickstand for parking
  1. #46
    Bmuused BMUUsed's Avatar
    Apr 2012
    Lemont, Illinois
    i use my sidestand most of the time. i added one of those bolt on pads to increase the footprint. when fueling, i'm usually sitting on the bike so i can hold it upright. i usually just use the centerstand for maintenance or to save garage space.
    At the tender age of five, a bear told me that only I could prevent forest fires. Why I was chosen, I'll never know.
  2. #47
    Registered User sit's Avatar
    Mar 2006
    Oregon
    Wow, lots of posts with nothing but opinions. You know your bike, you know how its loaded, you know the surface you are parking on. Park it on which ever stand you feel the most comfortable with for the set of circumstances.
    Now for the big question. Do you take it off the center stand while on the bike or standing next to it? I think it depends on whether you are using synthetic oil or not.
    2005 K1200LT-Ocean Blue
    2013 Ural Patrol - White
    2007 R1200GS-Granite Gray-Sold
    2004 R1150R-Titan Silver-Sold
  3. #48
    Diamondhead, MS
    Quote Originally Posted by Sit View Post
    It also depends on which battery and tires you have
  4. #49
    Nah! It is the nitrogen in the tires that makes it bounce if you are standing beside it.
    And the uneven pressure front to rear always makes it bounce away from you.
  5. #50
    Jul 2007
    Carol Stream, IL
    Side Stand
    I have an '04 R1100S "Boxer Prep", not equipped with a centerstand. I manage.
  6. #51
    Apr 2012
    Lemont, Illinois
    Now for the big question. Do you take it off the center stand while on the bike or standing next to it?[/QUOTE]
    If you're going to be standing next to it, you really should use the accessory center stand safety strap with the titanium retention clip to secure it to your belt so it doesn't get away from you. Model specific and only $376.95 at the dealer, but you might be able to find a used one.
  7. #52
    May 2012
    Escondido
    Quote Originally Posted by 182242 View Post
    That is a good idea, but get it with the optional upgrade-bungee cord, so it just bounces back up to you, like a 600 pound yo-yo.
    2000 R1100RT-P
  8. #53
    Feb 2007
    Sonoma County, Calif.
    Two reasons I use the center stand at all times:
    1. Can't really access hard cases while on side stand.
    2. Bike leans too much on side stand.
  9. #54
    Vancouver, B.C. Canada
    I only use the center stand while wearing lederhosen.
  10. #55
    May 2012
    Escondido
    I'm pretty sure I don't wanna see that.
    2000 R1100RT-P
  11. #56
    Registered User JoshuaTree's Avatar
    Jan 2011
    Austin, Texas, USA, Earth, SOL, Western Spiral Arm, Milky Way Galaxy
    Lightbulb
    ... Do you take it off the center stand while on the bike or standing next to it? I think it depends on whether you are using synthetic oil or not.
    "Take" it off the center stand? About 1 in 15-20 times I'll ride it off the center stand. (Probably not good for the longevity of the stand, engine case, etc.)
    Half of the time I'll just push it off the stand, the other times I'll rock it off the stand while on the bike. It mostly depends on whether or not I'm on level ground or "uphill".
    The only thing with leaving the bike on the sidestand is that I've found almost every time I've done so, I'll walk up to the bike with someone either on (or just about to get on) my bike.
    YMMV...
    Josh Friedman
    "Quis custodiet ipsos custodes?"
    "... Love Much, Laugh Often..."
  12. #57
    I use the centerstand 95% of the time. I only had it fall once. That was when the arm on the side of the stand broke off!! Has anyone else had that happen? The stand is hollow. I machined a solid insert and welded it back together. That fix has lasted ~10 yrs.
    1998 R1100RT
    FPB111 1998 R-RT
  13. #58
    need a fix for the side stand
    I primarily use the center stand only because the lean angle of my side stand is SO extreme. I'll only use the side stand if the ground is slightly sloping up that way.
    Any thoughts on how I can extend (or can it be adjusted) the side stand? I'm thinking upwards towards an inch or so.
    Please insert answer here: ________________________________________
    -Ride Safe & Avoid Anyone On The Phone-
    **2000 R1100RT (Bullfrog), 1976 R90/6 (Tadpole)**
    beemerFROG a.k.a. Douglas E. Rost
    MotoFrog.net -- Black Frog Marketing
  14. #59
    Jul 2003
    Murrells Inlet, S. C.
    Off the subject a bit: I never fill my tank while mounted. Rapid departure from a gasoline fire is enhanced by being off the bike. I also fear a mishap where gasoline is sprayed in my lap which seems much more likely when mounted. Gasoline you know is a strong skin irritant and particularly tender skin is close by.
  15. #60
    I use the centerstand because I can't reliably set my helmet or bag on the bike on the sidestand without it falling off. No problem with the sidestand, though. I have succumbed to the temptation of fueling on the bike. Twice as fast, and I get it topped all the way off, but it's just not smart.
    R75/6, 2004 R1150RTA.
