Results 1 to 6 of 6
Thread: K1200LT Tank bag
    ronshult
    K1200LT Tank bag
    Greetings. I am looking for a tank bag for the LT. I have the BMW but if I can get something a bit larger it would be great. Anyone have luck with anything? I still would like to get into the compartment. I have the factory BMW GPS and use it all the time. I see that Marsee has a system that bolts onto the oddment lid...not interested in drilling holes.
    Thank you
    Riding where it's hot! AZ-J's Avatar
    Mar 2007
    Scottsdale, AZ
    I use the BMW tank bag on mine, it is larger than my Marsees and is waterproof, the Marsee's need rain covers. I have since sold off one Marsee, and have another for sale (sold a 12L, have a an 11L).
    My bike shown here
    Jordan M, MOA #24434
    My Blog
    Registered User lkniess's Avatar
    Jul 2010
    Beaverton, OR
    I use ..
    I use a cortech super mini. It seems the right size for me. Its bigger than the 1200lt one but still allows access to radio controls. The map pocket could be bigger but I use GPS more than maps so I use the pocket for abbreviated notes only.
    http://www.motodisiac.com/blog/gear-...mini-tank-bag/
    Larry Kniess
    Beaverton, OR
    2003 BMW K1200LT
    2011 Can-Am Spyder RT-S SE5 Limited
    Registered User rmcclure's Avatar
    Dec 2009
    Erin, Ontario
    I use
    I use a bags connection enduro bag, available through twisted throttle. One strap loops around the stingray?? and two clips strap to the frame. No drilling, on and off in seconds, and will expand to a couple of inches higher by undoing a zipper so you can take home that rally tshirt you got when everything else is full already. I'm quite happy with it, but it would be better with a rain cover. It does have a water proof stuff sac to go inside, but that doesn't help the maps when it pours. Even so, when it pours rain, usually the maps will dry out.
    Ross
    K1200LT (99), DL650A (08), XJ650RJ (82)
    Registered User unigobill's Avatar
    Aug 2003
    Denison,Texas
    Tank bag
    After using a tank bag for 30+ years I have never been able to put up with a wimpy one, try this if you really need a full size bag. It will fit your LT by covering up the first 2" of your seat and you will be able to see your GPS and radio controls.
    Pictures on request
    The Rainier Tank Bag
    The Rainier Tank Bag is the result of combining the Ever-popular Explorer and Denali tank bags into one. We took the best of these bags to make the Rainier. By doing this wolfman has created the ultimate universal tank bag. Now one tank bag fits even more bikes than the Explorer or Denali. The mounting system allows the rider to adjust the fore-aft placement on the tank.
    The Rainier Tank Bag Features:
    ‘«ůYellow cord Main Opening Zippers
    ‘«ůHeavy Duty #10 YKK Main Zipper, and Ykk zippers used through out the bag.
    ‘«ůHeavy Duty 1680 Denier Ballistic Nylon Construction
    ‘«ůTough-Tek Non Slip-Non Scratch Bottom
    ‘«ůEnvelope Side and Rear Pockets for increased handle bar clearance
    ‘«ůWolfman Signature-‘«£Crescent ‘«£ Rider pocket.
    ‘«ůLarge Expansion Wedge shaped Gusset
    ‘«ůZippered Interior mesh pocket
    ‘«ůKey Clip Outside Elastic Pen/Tire Pressure Guage Sleeve
    ‘«ůRemoveable Map Pocket W/ interior divider
    ‘«ůReflective Side Pocket trim and Handle Foam and Plastic Stiffened.
    Bag comes complete with Map Pocket and mounting harness (you must choose)
    Dimensions:
    Length: 11"
    Width: 8 ?•‘«ō
    Height: front 6 ?Ę‘«ō rear 10‘«ō (facing rider) 14‘«ō Expanded
    Capacity:
    Closed: 17 Liters 1037cu.in. (Includes Side and Front pockets -each approx: .3liters 18cu.in.)
    Expands to 20 Liters 1220 cu.in.
    Map Pocket Size:
    Overall: 8 3/4" W x 10 5/8" L
    Visible: 7 5/8" W x 9" L
    Capacity: 20 liters regular, 24 liters expanded
    Color: Black
    Bullet Bill
    Worlds Oldest Unigo Dealer.
    May 2006
    Louisiana
    Would you post pictures of the bag as mounted on your LT?
