Results 1 to 2 of 2
Thread: Add on Electric Shifter
    Registered User miairhead's Avatar
    Jul 2008
    Otsego, Michigan
    Anyone know anything about this? I might be good to add to a hack for a rider that needs a shifter assistant. I have a brother with prosthesis on left leg, and therefore can not ride.
    Of course, none for a BMW but a universal that can be adapted to most bikes.
    http://www.pingelonline.com/eshifter.htm
    http://www.pingelcnc.com/pingelonlin...o_goldwing.htm
    Tom
    '84 R100RT '04 CLC(gone) Honda NT700V
    BMW
    Beer Motorcycles Women
    #13338 PGlaves's Avatar
    Oct 2003
    "Big Bend" TX
    Electric shift can be pretty simple.
    It is also fairly easy to mount a hand shifter to most BMW models. In a nutshell you need a handle with a knob, and an "L" leg on the bottom end where you mount it to pivot. Then connect the L to the transmission shift shaft and lever with a rod.
    A for and aft motion at the top will be an up or down motion at the L. Bob Mutchler has such a setup on his R11XX sidecar rig. This is not a really good picture but it is the best I have.
