Results 1 to 5 of 5
Thread: Low Beam Headlight
    nursedave
    Low Beam Headlight
    When I brought my K1600 the dealer told me if I wanted to turn on the low beam to click the switch twice. So how do you turn it off, cause the halo's on each side are the daylight running lights, that's what the manual says. Do you turn the parking lights off per the manual.
    Nov 2005
    Fairfax, VA
    Are you asking how to shut off the headlight when driving during the day?
    If yes, you can't, at least in the U.S. -- low beam always on here.
    Mark Neblett
    Fairfax, VA
    #32806
    nursedave
    I have to disagree. When I brought it the low beam was not on. Only the two halos. The says that the halos are the daylight running lights not the low beam.
    Nov 2005
    Fairfax, VA
    Quote Originally Posted by nursedave View Post
    Not correct.
    From the Rider's Manual:
    "Low-beam headlight
    The low-beam headlight switches
    on automatically when you start
    the engine."
    When the engine is running, the low beam is on (its controller does not automatically turn on the low beam when the ignition key is switched to the ON position; it waits until the engine is running; IIRC, when the kill switch is turned off, the controller turns off the low beam, while leaving the halos on). The halos are also on at the same time.
    The only thing different in daytime is the HID controller does not operate the adaptive headlight's mirror to follow turns (obviously no need to do so in daylight, and thereby eliminates unnecessary wear/tear on the mirror motors and linkages).
    Mark Neblett
    Fairfax, VA
    #32806
    nursedave
    So I wonder why I had to activate it. It wasn't on when I drove it home just the halos.
