Results 1 to 3 of 3
Thread: continental divide ride?
    Im thinking of riding the Continental Divide and would appreciate any comments esp those who have done it. Should I do it with a group? Just where can i get a decent map of the ride? I have a GS 1150. When is the best time to do it?
    Thanks in advance
    Paul Violand
    tthousesaustin@gmail.com
    BACKROAD.ADV
    Expect lots of dust…….
    Riding in a group is helpful but not necessary. If something goes wrong, need to fix a flat, etc a group can be helpful. Also certain resources can be shared reducing the weight each member carries; i.e. cooking equipment, tools, etc.
    Starting later in the summer season- late July/Aug/early Sept-- helps reduce problems with snowpack at the higher elevations (depends on the amount of snowfall that occurred the winter before). Provided its not too late in the season and a winter weather pattern roles in. Also a later in the season; fewer daylight hours, mornings at elevation can be real cold. But I have been snowed on in the Rocky's in July and Aug if the weather patterns are just right (err…. wrong?)
    Here are some resources:
    Big Dog Adventures
    Murgatoid42 Does the Continental Divide-ADV Forum
    Two Tail Dogs RR
    Les Stark RR
    Jacohamman RR
    Hope this will get you started.
    A Book Recommendation from Whitehorse Press
    Mar 2005
    San Tan Valley, Az
    Check out this thread from Adv rider:
    http://advrider.com/forums/showthread.php?t=251600
    Also, check into the rides offered by Jim Hyde at Rawhyde Adventrues. He has a couple of groups each year going both directions.
    If I were doing it for the first time, I would prefer to be with a group if for nothing else, moral support.
    bob
