Results 1 to 7 of 7
Thread: Luggage lights
    Luggage lights
    Anyone found a solution for getting some light into the topbox and/or saddlebags? Found this on the net today. They don't seem that bright to me.
    Toplite
    100,000+ miler 32232's Avatar
    Southwestern Ontario
    Lowes or Home Depot have battery powered LED closet lights that should do the trick.
    Dave
    Jul 2007
    THE BIG SKY
    Quote Originally Posted by 32232 View Post
    lowes or home depot have battery powered led closet lights that should do the trick.
    +1
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    Pismo Beach, CA
    Whoaaa!! $47.95.... for the TopFlite battery powered LED "closed light"?!?!
    6" 6-LED strip light at ACE Hardware
    ...read the customer review; $11.99
    Disclaimer - I have no affiliation with ACE
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    Great suggestions. I like that Ace hardware 6 LED light.
    Certifiable User Mike_Philippens's Avatar
    Feb 2011
    The Old Country
    Isn't it much more practical to pack a headlamp as standard on your bike? It's something you need anyway: in case of a breakdown in the dark etc. Just pack a headlamp in you tankbag or in the topcase (loose on the side).
    -=- if you always see the road ahead of you, it's not worth the trip -=-
    Eastern KY
    Wally World has one that is not only cheap @ ~ $7+, it is much better than the other 2 I have from the pricey brands! It is an LED type , uses 3 AAA's & very lightweight & compact. Closet lights, not good , even for closets...
