Results 1 to 15 of 27
Thread: $50.00 a quart!
    Dec 2007
    Midwest
    $50.00 a quart!
    Service manager tells me my $24.95 a quart rear drive fluid has been surpassed by BMW's own new rear drive lube for the K1600. The new BMW recommended gear lube for K1600 is $50.00 quart. Not sure what change interval is, but only "life time" fill would be acceptable....Oh wait...they already did that once, didn't they?
    MOA #46783
    2009 R1200RT
    Rally Rat RTRandy's Avatar
    Feb 2004
    Dallas, Texas
    Rear drive oil is expensive, however the dealer only uses a small portion of the container ( measured in CC's). The kicker is when they do a service, they charge you for a full bottle as if it comes from the parts department.
    Can't speak specifically for the 1600's since no idea how much is needed, but you can go to the parts counter and buy yourself the quart. When it comes time for service, bring your bottle and tell them to use your oil so there's no rear drive oil charge. They return the unused portion when you pick up the bike.
    This isn't the same as trying to bring the dealer your own crank case oil from Walmart to save money. They use like a fifth of that rear drive fluid ( if that) from that bottle for a service. Not sure if some dealers only charge you for the portion used, but I know some charge you for the entire bottle.
    neanderssance man sedanman's Avatar
    Jul 2011
    Pawling NY
    Well I feel good about my dealer now. My itemized invoice for my 600 mile service shows .1 quart of gear oil. They break it down to the tenth of a quart. Next time you go for a f/d service, TELL them you want the rest of the bottle. If they are going to charge you for it, they have to give it to you. If they don't give it to you make them show you how they used the whole thing on your bike.
    Paul
    Stop wrestling with your motorcycle, dance with it.
    2011 R1200RT Traded
    2014 R1200RT fully optioned
    Dec 2007
    Midwest
    Exactly
    And that's what I do...I buy a quart and use it 180cc at a time. If I go for a dealer service, I bring the bottle along...never had a problem with dealer over it. However, when it gets to $50.00 a quart I may keep it in my bank's Safety Deposit box between services.
    MOA #46783
    2009 R1200RT
    Aug 2003
    Marion,Ar.
    Black Gold, Texas T, and the first thing You know ol' Jeds a millionaire. At $50 a pop make that a Billionaire.
    Registered User realworld51's Avatar
    Mar 2011
    Canton, MI USA
    My dealer is using up a significant supply of the old (but still worthy) BMW FD oil, and charged me $6 for the fill at my GT's 600-mile service. But at checkout, he proudly showed off a bottle of the new stuff...at $47.95 per quart. Miracle formulation? Maybe, but in small print on the back of the bottle, still 75-90 weight gear oil.
    Steve W
    Canton, MI USA
    2012 K 1600 GT (from 8/6/2011)
    Apr 2008
    SW Ohio
    I wonder if BMW has thought of BMW-branded-gasoline available only through authorized dealers at $12/gal. Sad thing is, some people probably would swear by it.
    1987 K75S
    Original litter
    Original owner
    2012 Ural Gear Up
    Aug 2006
    Scranton, Pa.
    $50 per quart rear drive oil.
    The cynical truth is that BMW has a hard core group of Koolaid drinkers who believe that ANYTHING that says BMW on it must be the best in the world and they exploit them. They are most probably related to the group of people with no German blood who try to "Out German" folks at BMW Motorcycle and Car Club events. That having been said, the best course is to do your own research and buy the best oil you can find. You may wish to look at products from Pentasynth (sp?) and Red Line Synthetic. Finally, oil is still cheaper than getting flatbedded 150 miles through the desert for a final drive rebuild.
    Regards,
    Will3hawks
    Sep 2008
    Wilmington, NC
    Rumor has it that this same fd oil is available at Range Rover places forabout $20.
    Haven't confimed it but wouldn't surprise me given the markup on BMW parts.
    On the road again! R80RTJohnny's Avatar
    Ottawa, Ontario, Canada
    Quote Originally Posted by barryg View Post
    Great post!
    2008 R12RT (Blue)
    1986 R80RT (Silver)
    Member of the Loonie-Tics. MOA 292.
    Pressing #1 for English! tictac's Avatar
    Apr 2006
    SOUTH FLORIDA
    Quote Originally Posted by Motodan View Post
    I really don't know what oil BMW uses for FD in K1600 bike. The oil is probably very very special. I think they are pumping it right out of the President Medvedev's office. But I don't think that special BMW oil specs are better than just a SYNTHETIC Amsoil. Here is the description for the Amsoil rated 75-90 for a 12 bucks a quart.
    Product Description: Severe Gear?ę Synthetic Extreme Pressure (EP) Gear Lube 75W-90
    AMSOIL Severe Gear?ę Synthetic Extreme Pressure (EP) Gear Lube is a premium-grade gear oil specifically engineered for maximum performance in severe duty applications. This state-of-the-art AMSOIL formulation features an exclusive blend of high viscosity, shear stable synthetic base oils and an extra treatment of high-performance additives. AMSOIL Severe Gear Synthetic EP Gear Lube maintains its viscosity for long-lasting protection against metal-to-metal contact. The proprietary AMSOIL additives form an iron-sulfide barrier coating on gear surfaces, providing the ultimate line of defense against wear, pitting and scoring. AMSOIL Severe Gear helps prevent ‘«£thermal runaway‘«ō ‘«Ų a phenomenon caused by a lubricant‘«÷s inability to control friction and increased heat under high-stress conditions. By controlling thermal runaway, AMSOIL Severe Gear?ę Synthetic EP Gear Lube inhibits rapid lubricant degradation and component damage. Equipment runs better and lasts longer with AMSOIL Severe Gear Synthetic EP Gear Lube.
    Performance
    AMSOIL Severe Gear provides performance beyond that possible with conventional gear oil. This AMSOIL custom product offers superior gear and bearing protection, better friction and heat reduction, increased efficiency and extended service life.
    Temperature Extremes
    AMSOIL Severe Gear EP Gear Lube excels in hot and cold temperature extremes. By design, it resists breakdown from high heat, preventing acids and carbon/varnish formation. Its wax-free construction also improves cold-flow properties, improving fuel economy and cold weather shifting.
    Applications
    AMSOIL Severe Gear Synthetic EP Gear Lube is excellent for severe applications, such as towing, hauling, steep-hill driving, commercial use, plowing, racing, off-road use, rapid acceleration, frequent stop-and-go operation and high ambient temperatures. Higher horsepower, towing and hauling capabilities of modern vehicles make turbo-diesel pick-ups, SUVs, vans and delivery/utility vehicles especially prone to severe service. Other severe-duty vehicles include light, medium and heavy-duty trucks, buses, heavy equipment, 4X4s, tow trucks, race cars, tractors, and motor homes.
    Superior Film Strength
    Controls Thermal Runaway
    Rust and Corrosion protection
    Reduced Operating Temperatures
    Improved Efficiency
    Longer Oil, Seal, & Equipment Life
    50 bucks for a quart of oil.:
    What is next? 500 dollars for a very special 6 spark plugs?
    2002 R1150R
    2003 F650CS
    2004 R1150RA
    Bye Bye 2006 K1200LT
    Rocky Bow BMW Riders #197 bogthebasher's Avatar
    Apr 2008
    Calgary AB
    ...my Dealer is selling the Castrol 75W90 Synthetic for $47 a litre (they put a white sticker onnthe proclaiming "for BMW"). Guess that makes it worth more 2X what Auto Value sells it for...
    Ken Dittrick
    2008 R1200RT (Biarritz Blau)
    Excuses are the rocks upon which our dreams are crushed - Tim Fargo
    Polarbear Polarbear's Avatar
    Clovis,CA
    Put more $$ into oil R and D, it couldn't be the FD design and parts failing. Its got to be the oils fault, so we must redevelope it more, even to 50 bucks worth.! Boy, is somebody being spoonfed something. The same marketing department has brought us 25$ oil filters,etcetc...... Ugly! Ya'll keep eat'in this, not me. Change only happens when they notice the dollars don't go there anymore! Randy
    beekeeper beekeeper's Avatar
    Oct 2006
    Western Massachusetts
    I use AMSOIL Severe Gear oil. FD only uses 180ml so there are several oil changes per Qt.
    Just north of Seattle, WA
    I chuckle every time I read someone's complaints about the exorbitant costs to service and maintain a $25,000 motorcycle.
    Guess you should have bought the Kawasaki Concours instead. Then you'd have $10,000 left over for parts and fluids.
    Seattle, WA
    2012 R1200GSA
    2002 R1150RT-P
    1992 K75S sold
