Results 1 to 9 of 9
Thread: Does anyone make one of these?
    Peter_Krynicki
    An electronic unit I can plug into a wall outlet in my garage, then plug in the "cigarette lighter" type plug into it? Instead of moving the jeep and bike around so that the phug and tire connector will each reach?
    MOA #24991 Pauls1150's Avatar
    Apr 2008
    south of Los Angeles
    Could you please be a little more specific about exactly what you are trying to do?
    Are you trying to extend a battery charger, or a tire pump?
    Both issues can be solved with a simple extension cord.
    Mansfield,MA
    While I'm not exactly sure of what your trying to do take a look at this http://www.adorama.com/KD12VAC1245.h...m_source=gbase There are a bunch of ways to get a 12 volt lead out. HTH Gary
    Mod Squad
    2009 F800GS 1994 TW200
    Jul 2007
    THE BIG SKY
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    Peter_Krynicki
    The last two look like they will work. I'm going to print out the pages and stop by the local PEP boys and see what they have to offer.
    Thanks!
    Mar 2005
    San Tan Valley, Az
    If you don't find what you are looking for at PEP boys, Radio Shack has the same item.
    The one I have at my desk at work to charge my phone: Cat. No 22-505A
    Check two things:
    How many amps will your load need, and how many amps the little unit can put out.
    Some may work fine to charge a cell phone and fail to power a tire pump.
    Eastern KY
    You ask who makes one & I am guessssssssing that the Chinese do make that item...
    Peter_Krynicki
    Once I knew what they were called it was amazing how many of there there are. I ordered a one made by Black & Decker and will report on how well it works out. If it just works with either of the two tire pumps I have, it will save a lot of hassel.
