Results 1 to 5 of 5
Thread: Wunderlich Throttle Lock
    Registered User clowry's Avatar
    Sep 2006
    Oakville, ON
    I bought one of these at the rally and Dave installed it on my '04 F650CS for the ride home, but it doesn't seem to work properly. I tried it several times, tightening it down as far as I could, but there doesn't seem to be enough friction created to actually hold the throttle. As soon as I relax my hold on the grip the speed starts to drop. Any suggestions on how to improve it before I pack it up and send it back? I have emailed Wunderlich for help as well, but they're out of the office for another few days.
    Thanks!
    Registered User Woodbutcher's Avatar
    May 2010
    Austin, TX
    I don't have one, but they are similar to some others on the market. As you tighten it, it snugs up against the end of the throttle tube. So the problem is that there is too much gap between the throttle tube and the lock. One reason could be the throttle lock is not all the way up against the end of the handle bar. The more likely reason is the throttle tube is shifted up the handle bar. I don't know exactly how your switch gear is, but the basic process would be to loosen the switch gear/throttle assembly (some bikes they are separate, some the are single piece) and sliding it towards the end of the handlebars a little bit then tightening them down. Some bikes have a pin that forces the assembly to only be in one position though. Once again, I don't know if yours is that way or not.
    If you've adjusted the position of the handlebars before, you may have moved the throttle assembly so the switches are still reachable and accidentally shifted the assembly inwards. So that could be why they are in the wrong position.
    Anyway, that's how I'd fix it, by moving the throttle tube out on the bars.
    Hope that helps and you get it working.
    Rusty
    Austin, TX
    Two Wheeled Texans
    2009 R1200GSA 2013 K1600GT
    Sep 2006
    Oakville, ON
    Thanks for the insight, Rusty. I'll give it a try and let you know how it goes.
    Cheryl
    Registered User LMIWA156120's Avatar
    Mar 2010
    Galway, Ireland
    If it was really hot at the rally when the throttle lock was installed and it is now cooler, then just the difference in temp may be causing the issue.
    I have a throttlemaster lock on mine and the expansion/contraction of the throttle tube makes it impossible to adjust it so that it works all year around.
    I have it set so that in the summer when it's really hot (>100F road temp), it will drag just a little bit even when completely released. However, when it gets colder (<40F) it won't hold the throttle even when cranked all the way on - until I turn on the warmers.
    I suspect that you will have to adjust yours (as mentioned above) to some compromise position that works for most of your riding.
    Just my experiences...
    Loch Miwa
    Galway, Ireland
    2006 R1200GS
    Sep 2006
    Oakville, ON
    Ahhh - that's a very good point! It was VERY hot at the rally, and not quite as hot on the way home (it was overcast). Thanks for pointing that out. I've actually found a short video from Wunderlich showing the adjustment process. I'll get to it after dinner!
