Results 1 to 15 of 29
Thread: fuel capacity 08 12RT
    May 2011
    South Kentucky
    When the estimated range reading on the BC is below 10 miles I can get about 6.1 to 6.3 gallons of gas in the tank. That's on level ground on the center stand.
    Should I trust that I have approx a gallon of fuel left or is it just too difficult to completely fill the tank on these bikes
    Anthony S.
    2012 R1200GS
    R1200RT Artiee's Avatar
    Jul 2008
    Northern Virginia
    I have an 05 RT (no computer though). Several times I've run my fuel gauge down to empty on my display to test how far I could go on average on a tank of gas -- followed by immediately pulling into a gas station to fill up. (By empty, I mean the last pixal on the digital fuel gauge winked out.) In every instance, the fuel tank took approximately six gallons (give or take a tenth).
    Given that I have 7.1 gallon fuel tank, I take that to mean I have one gallon left. The only way to know for certain if that is accurate would be to continue riding until the engine quites from fuel starvation -- I'm not willing to test that though.
    I would say it's a good bet you too have approximately one gallon left.
    (My rule of thumb when on the road is to start looking for a gas station at 250 miles on the tank of gas. At 275 miles on the tank of gas, I'm looking to pull in at the very next station I see.)
    May 2011
    South Kentucky
    My odometer reading on the trip is showing that I've gone approx. 300 miles and the mpg at about 54 and that I have a range of 10 miles. That's when I filled up and put in 6.1 gallons.
    That would indicate that my reserve warning light is coming on when I have about two gallons of fuel left
    I'm a bit nervous about pushing it further. Like you I don't want to run it dry but it sure would be nice to know how much gas is left in the tank.
    Gone are the days of a simple petcock connection to drain the tank
    Anthony S.
    2012 R1200GS
    Registered User marcopolo's Avatar
    Feb 2005
    Alexandria Virginia/Ottawa, Canada
    Interestingly, within the last couple of years, BMW changed the specs to indicate 25L of useable capacity, whereas they used to say 27L of useable capacity in the tank. I don't believe the tank itself was changed, though I stand to be corrected on that.
    Mark
    2015 R 1200 GS Adventure
    Sheboygan, WI
    Smile
    Quote Originally Posted by Artiee View Post
    +1!
    When the "miles to empty" zeroes out, you've got about a gallon left in the tank yet. However, since some fuel lubes the fuel pump, going bone dry is never recommended.
    I always find a gas station before I zero out.
    Sep 2007
    So. Calif.
    What fooled me is that the gauge reading and the miles-to-empty calculation both gradually changed. What I thought I knew at 15K miles was no longer accurate at 30K miles - so I ran out of fuel twice.
    IMO, the odometer is the most reliable fuel gauge - I try to fill up at around 250 mi.
    '14 R1200GS,
    Priors: '13 K1600GT, '08 R1200RT, '04 R1150RT, '05 R1200GS, '73 R75/5.
    dstuckmann
    My '08 RT recently took a bit over 7 gallons when I had the computer down to 10-15 miles. It has about 26,000 on the clock.
    Note: I have removed the rubber fill ring so the fill was to the bottom of the steel neck...
    I recently put 6.3 gallons into my '09 R1200RT with 315 miles showing on trip odometer. The fuel gauge still showed about halfway between the 1/4 and empty marks so that should indicate about 1/8th of a tank remaining.
    I'm aware that the '09 owner's manual supplement says the tank only holds 25 liters or 6.6 gallons. If true, then I was only .3 gallons from empty.
    As a routine habit, I always zero out the trip odometer when refueling. In this instance, I really pushed too far and was lucky not to run out of gas.
    Since then, I've been watching the fuel gauge more closely. Either the gauge is miscalibrated, going bad, or my tank actually holds the 27 liters/7.1 gallons that the older RTs did. The gauge and OBC typically show I can go farther than the actual fuel remaining. For example, my trip odometer reading added to the OBC miles to go often total to 375 miles when approaching 1/4 tank remaining!
    I too miss the reserve petcock from older bikes. Simple, but effective.
    Lee
    May 2011
    South Kentucky
    "I recently put 6.3 gallons into my '09 R1200RT with 315 miles showing on trip odometer. The fuel gauge still showed about halfway between the 1/4 and empty marks so that should indicate about 1/8th of a tank remaining."
    That pretty much duplicates my experience although I'm not sure my gauge is between 1/4 and empty. I'll have to check that next fill up. My owners manual states 27 liters
    Anthony S.
    2012 R1200GS
    Quote Originally Posted by sloride View Post
    I was given a separate page addendum for the '09 owners manual which says the capacity is 25 liters. The manual itself says 27 liters.
    The 2010 model definitely is listed as 25 liters.
    I'd be interested in hearing your results on the next fill up. You have an '09, right?
    Lanesville, Indiana
    So why not test the accuracy of the fuel guage and carry a gallon of gas with you. That way you'd know how far you could go after the guage said empty. I've thought about doing that just to see how far I could go after the guage read 0 miles. Would be interesting but, I haven't been that concerned. It's like the gas guage in the car, you can't trust it either. I start looking for gas when I hit the one fourth mark or sooner.
    May 2011
    South Kentucky
    Quote Originally Posted by H.Ellars View Post
    So why not test the accuracy of the fuel guage and carry a gallon of gas with you. That way you'd know how far you could go after the guage said empty. I've thought about doing that just to see how far I could go after the guage read 0 miles. Would be interesting but, I haven't been that concerned. It's like the gas guage in the car, you can't trust it eithere. I start looking for gas when I hit the one fourth mark or sooner.
    You would probably still have to run out of gas before adding a gallon to know for sure. I don't really want to run the bike dry. I may just settle on the 300 mile mark as empty or maybe a little less when traveling at interstate speeds.
    Is ther really a difference in capacity after the 08 bikes?
    Anthony S.
    2012 R1200GS
    I'm not expert on this, but several people have posted in other threads that the fuel pump is cooled by the fuel in the tank. So if you run the tank dry, then the fuel pump can be damaged; perhaps not causing an immediate failure, but long term damage.
    May 2011
    South Kentucky
    Checked OEM numbers and the fuel tank changed 8/2008 . That must be the beginning of the 25 liter tank.
    16117682839 up to 8/2008 then 16117699595
    Anthony S.
    2012 R1200GS
    Sep 2009
    Chestnut Hill, MA
    Fuel Strip Failure
    Considering the substantial number of fuel-strip failures (including mine at 9600 miles) the best planning is to start looking for the next station after 250 miles rolls up on the ODO since the last fill-up. Besides, summer or winter, your bod is looking for some hydration...
    John Gamel
    2015 Ebony Metallic R1200RT
    BMW CCA 2006 - Present; BMW MOA 2009-Present
    Walt Kelly: "We have met the enemy, and he is us."
