Results 1 to 3 of 3
Thread: Brighter Headlights
    F-V, NC
    Brighter Headlights
    Has anyone else tried running brighter headlights in their motorcycle?
    I currently use an 80/100W light but noticed that the socket and rubber boot have melted a little from the extra heat. I've bought a replacement socket but haven't used it yet.
    The spade connectors are probably rated at 5A. The brighter lights would be pulling about 7.5-8.5A. The wire capacity should be fine but I don't want to keep replacing sockets if I don't have to.
    Just looking for some comparisons.
    thanks
    '88 K100RS ABS
    Focused kbasa's Avatar
    Marin By God County, California
    Re: Brighter Headlights
    thanks
    I've run 55/100W bulbs without difficulty, but really only ran the high beam at night.
    Dave Swider
    Marin County, CA
    Some bikes. Some with motors, some without.
    Blocking the slow lane
    Elburn, IL
    I could never get a high-output bulb to last in my K75, but eventually added relays after a wiring issue. Now I have no need for a bigger bulb....the direct connection produces a lot more light than the stock setup. See IBMWR.org for details on adding relays.
    Jon Diaz
    BMW K75/K12GT
    BMWMOA Ambassador
