Results 1 to 7 of 7
Thread: Rear tire cracks on K75 - Battlax BT45
    Aug 2006
    Grand Rapids, MI
    This is the second rear BT45 that I have had the same problem with on my K75. On the first tire I noticed the problem at 4000 miles this one 5000. From other posts it seems 6000 is the norm for wear but this shouldn't be a normal wear pattern. I really like the way the bike handles with the Battlax 45's but I think it's time to try a different brand. Other members have posted that they have had similar issues with other brands but has anyone experienced this twice?
    lostandwandering
    2008 R1200R
    previous 87 K75S (crashed)
    Proud Veteran SteveAikens's Avatar
    Clovis, NM
    Look for the tires date of manufacture. It's the 4 number stamp you'll find on the sidewall. It's read as [for this week in 2011] 2311. That's the 23rd week of 2011.
    If the tire is more than a few years old and with you living in MI, you have a shorter riding season then others do, so I'd expect you'll likely see this before you see a tire wear out. That's not necessarily the case, but it's normal for that area. I lived in Port Austin for a while.
    What you're experiencing is simple dry rot. It's the tire's way of saying it's not safe to ride on.
    Nom de Plume:
    Steve Aikens, Clovis, NM
    BMW MOA #6218
    IBA# 442
    Aug 2006
    Grand Rapids, MI
    Tire Cracks continued
    The tire's serial number indicates 2010, that'd be the week of May 16 - 22, 2010, just over a year old which should rule out dry rot. Some kind of rot but not dry rot.
    The front tire also a Battlax 45 purchased at the same time as the first rear tire that showed this problem, was manufactured the week of June 28 - July 4 2009; that tire shows a bit of cupping but no other severe wear. None of the tires were purchased from a big web based warehouse, I like to support my dealer whenever possible.
    lostandwandering
    2008 R1200R
    Clovis, NM
    Quote Originally Posted by lostandwandering View Post
    Most definately. Return to your dealer and let them contact Bridgestone for a replacement. It happens - just a bad tire.
    Nom de Plume:
    BMW MOA #6218
    IBA# 442
    Wilmington, NC
    Rubber is very ozone sensitive and also to some solvent vapors. Any change your bike is stored near a bunch of electrical gear or wrong chemicals? More likely just a bad tire but if I got two of these on the same brand, I'd change brands.
    Have no experience with the tire you use but certainly was underwhelmed with the BT-020's that were stock on my RT. The worst current tire in its class IMO.
    They didn't rot but that's about he only bad thing they didn't do. Among their less than endearing properties were tramlining, bad behavior on steel bridge grates, crappy traction in the cold and wet, and more but at least they wore out fast.
    Dances With Sheep GREGFEELER's Avatar
    Boise, ID
    That certainly looks like a warranty issue to me. I'm on the last half of my first set of BT45's on one of my K75's and expect to get at least 7,500 miles out of them. I liked them so well I put a set on another K75. I know a number of people who use nothing else and have never heard of this kind of a problem.
    Greg Feeler
    BMW MOA Director & Ambassador
    1972 R75/5, 1990 K75, 1990 K1, 1992 K75S, 2003 K1200RS
    Registered User abcindy's Avatar
    Sep 2007
    Indianapolis
    I had the same thing last year on my 92 K75. This was my 2nd Battlax BT45. Got t 10600 miles on the first, then on the second I got the same type of split in the tread as your photos at 4200 miles. The local shop that I got the tire from replaced it with another Battlax and I got 9800 from the replacement.
    Andy Clark
    Indianapolis, IN
    1992 BMW K75
    BMWMOA, AMA, IBA
    Indianapolis BMW Club
