Results 1 to 15 of 60
Thread: does anybody here use pulsing brake lights?
    mattituck new york
    also, i learned a lesson about left turns on two lane roads at night. i was on a curve stopped to make a left turn.... heard a screech behind me which was the attention deficit disorder afflicted driver swerving to avoid me.
    it was then i remembered hearing somewhere that in that kind of a scenario it's best to pull off to the right and let the road clear and then make the left turn.
    the other driver might have been at fault but i was the one who would have been road kill.
    hope this helps somebody else.
    GREGFUESS
    Stop Alert
    There are some products out there to pulse the break lights. Amperite Stop-Alert 2M Stop-Alert Brake Light Pulsator is one, but there are others. They seem to work well. Hyperlites also pulse the brake light if you install the running-turn indicator-brake light gizmo. Hyperlites use LED lights, and are plenty bright.
    Personally, I try to avoid riding at night. My eyes aren't what they used to be, there is lots more traffic on the road and the drivers (especially around Houston) seem to be more aggressive every year.
    One thing to keep in mind with any traffic situation is how fast a motorcycle can stop in comparison to a car or other larger vehicle. An emergency stop on a motorcycle causes cars and larger vehicles considerable trouble as they cannot stop in nearly as short a distance as you can on a motorcycle. Good reason to be aware of where you are if you have to ride in traffic, and to indicate your intentions with plenty of warning, avoiding sudden manouvers.
    rabid reader dbrick's Avatar
    Santa Cruz CA
    I've had pulsing brake lights on my last three bikes, since 1988. I perceive that cars keep a greater distance, and seem to react more quickly, than when I ride machines with solid-on brake lights.
    Moving out of the way is good, but you have to be aware of what's happening behind you *before* the screech in order to have time to do it.
    FWIW, I also avoid riding at night.
    David Brick
    Santa Cruz CA
    2007 R1200R
    Aug 2005
    Charlotte, NC
    I use all of the above
    reflective tape on the hard bags, blinky brake lights, and i don't relax until there is at least one car STOPPED behind me.
    It's saved my bacon more than once.....
    Enjoying the ride, but always on the alert for a rally.......
    ADVENTURETECH LED brake light in my 2007 GS. Much brighter and adjustable pulse duration.
    Mansfield,MA
    Hi everyone, I'm going to move this over to the Gear part of the forum. As it happens we have a similar thread running for headlights. Now both ends will be covered almost next to each other. Thanks, Gary
    Mod Squad
    2009 F800GS 1994 TW200
    Nov 2003
    Dartmouth, Massachusetts
    Yes..........on every bike I own
    RoyB....
    2007 BMW K1200R Sport (abs),2007 Suzuki dl650 V Strom (abs),2004 Honda VFR (abs),1972 Honda Trail 90,
    2001 Moto Guzzi V-11 Rosso Mandello
    I have Hyper-Lites on every bike I own.
    ________________________________________
    The early bird might get the worm, but the second mouse gets the cheese.
    Registered User ALIENHITCHHIKER's Avatar
    Oct 2004
    Asheville, NC
    Hyperlites, Kissan Signal Minder (which converts the turn signals to marker lights as an option), LED lights wired into the stoplight (intended to mounted as turn signals on the mirrors) & just about any other shiny thing I can think of.
    I still got rear ended.
    Maybe I blinded the driver.
    (Actually, she let her car inch forward while she was looking over her left shoulder - made contact with my side case, pushing me over. Just goes to show.)
    Steve
    Current Hottie: '00 R1100RT
    Old Flames: FY K100RT, '80 XS850 with Vetter Quicksilver, '67 Bonnie, '66 Honda 90
    YES!!!
    I started with Kisan tail blazers. The dealer said they would vex the can't bus, so I got them online. A year later, I had the OEM led tail light installed (dealer said it was too tricky for me to do it). Any way, yes use anything to let the texting, phone-talking, make up applying, G3 surfing, etc. driver know you've stopped. Also, check six and re-pulse the brake lights every few seconds. Be ready to split lanes and go! if the stupid cage-er is coming in hot.
    Rubber down,
    Rich
    Edit: I bought hyperlites but their spade connections didn't fit mine, so no joy there. Some day I'll retro-fit to my bike.
    Rw
    RichW
    2007 R12RT
    DS/DS, OEF, OIF
    Sheboygan, WI
    Thumbs up
    Hyper-Lites!
    Fantastic rear visibility for approaching motorists.
    They will be on any bike I own from now on.
    Registered User Daedalus214's Avatar
    Aug 2008
    Cary, IL
    +1 Signal Minder
    The Kisan Signal Minder is easy to install (just replace one relay) and works very well on my R100R. People who follow me always mention my blinking stop light; highly recommended!!
    Dec 2009
    Hudson Valley, NY
    I have Skene Design P3 LED lights on my RT and think they are the best addition that I have made. I wouldn't have another bike without them. There is certainly a noticeable difference in the amount of distance that most cars leave behind me with the obnoxious (in a good way) flicker and strobing features. I also like that the P3s are easily programmable and are very easy to install. Highly recommended!
    Craig
    2009 R1200RT
    MOA #146131 IBA #55715
    Kbiker BCKRider's Avatar
    Jan 2009
    B.C. Canada
    Quote Originally Posted by cscatola View Post
    I completely agree with cscatola, but there are certainly many alternatives. Just try to remember to get OFF the brakes after you are stopped at a light then reapply them
    a time or two as vehicles approach you to re-activate the flash. Riding curvy roads, if somebody is following you, use the brake lightly, even if you could achieve desired entry speed with just down-shifting. You want to give them fair warning to back off, and pulsing brake lights do that very effectively.
    Making a left turn off a busy secondary highway (the other topic of the OP) with no left turn lane can be a dicey business, even in daylight. I certainly don't want to come to a stop near the center line for oncoming traffic and expect following vehicles to either stop behind me or pull over partly on the right shoulder, even if it is paved, to zip on past. I'm just not that trusting. When making one well-known left turn, I try to put a sizeable gap between me and following vehicles - either passing them well before the turn and running speeds that LEO's might frown at - or slowing down if that creates a big gap between me and following vehicles. Then you have to adjust your speed to make a left turn in a sizeable gap before or after the oncoming vehicles, while still making sure nobody has snuck up behind you. Options:
    1. Clear in front and rear? No problem.
    2. Clear in front, but vehicle approaching fast from the rear? Signal left and pull into the oncoming lane, brake hard, and make the turn.
    3. Oncoming traffic and a vehicle behind you, but with a wide paved shoulder? Signal right and come to a stop before your turn as far away from traffic as you can get. Then signal left and, when traffic clears in both directions, get out on the road and make your turn.
    4. Oncoming traffic, a vehicle behind you, and minimal paved shoulder? Just keep going. Either take a longer route or make a right turn on the next paved road and make a u-turn to get back to the road you wanted, which is now a right turn.
    Interesting post. I firmly believe that anything which adds to our conspicuity decreases our chances of being nailed by an inattentive motorist, but it never reduces those chances to zero. Having a "riding plan" which includes pre-thinking what you will do in various situations (as above on making a left turn) also greatly reduces our chances of having an accident. But again, never to zero.
    I think one of the big attractions of riding a motorcycle is "managing the odds." We are very aware that the dichotomy of safe vs dangerous is a myth. While I try to carry that attitude when I'm driving a car, I just feel more alive on the bike.
    Doug
    1992 K100RS
    TravelsWithBarley.com
    Jan 2009
    Craftsbury, Vermont
    Another vote for the Skene P3 lights. I have them and the no longer offered Brake! lights on both of my 12GSes along with plenty of reflective stuff. That said, those things do not absolve me of the responsibility of being aware of my surroundings, of always leaving myself an out.
    Rich -- I know that dealer! The "anything made by BMW is okay but only if installed by a trained technician -- every other product will mess up the computer and do you want to take a $2700 risk?" dealer.
    Pete
    '12 R1200GSA for solo rides
    '10 R1200GSA with Hannigan dual sport sidecar for rides with Tulliver
