Results 1 to 15 of 23
Thread: Radar Detector Mounting
    Aug 2010
    Salt Lake City
    I have ordered a radar detector that should be here in a couple of days. I could go on a rant why I bought one but let's not. I also bought an accessory shelf for my 2010 RT which I have installed. My plan is to just Velcro the detector to the shelf. I already have ram mounted gadgets on the steering head. Anyone else use a similar setup and will it work well there or does it need to be higher?
    Aug 2010
    Collinsville IL
    mount
    I have my 09 rt mount it on the shelf above the guages,works just fine. Even cruising rainy weather
    2014 R1200RT
    Now gone 09 RT
    10xxx and going!
    living for riding,riding reason to live!
    GIZMO
    Although not an RT, I had a shelf with radar attached by velcro on a previous LT and doing the same on my new LT. It works well, very secure and easy to place & remove.
    May 2007
    Raleigh, NC
    I mounted mine with Velcro just off to the right side of center above the gauges. I did not get a shelf so it aims down a bit, still works great. I need to replace the velcro once a year or so. I've had it pop off at speed so a lanyard, or in my case, a very solid audio and electrical connection saved me from losing it.
    Rob C. , Raleigh, NC
    '10 R12RT, R90/6
    2007 CBR600RR & 09 V-Star
    Suzuki DR 350
    GIZMO
    Quote Originally Posted by RoboRider View Post
    Did you use industrial strength Velcro? I have used the stronger industrial strength and never had it shift, much less come loose. On my first LT, I never replaced the Velcro in 3-years.
    May 2007
    Raleigh, NC
    The industrial strength holds TOO well. I would go to remove it and the velcro would come off the detector and stay hooked. Since I remove the detector every time I leave the bike to eat, etc., I went with lesser strength. It works fine, I just have to put on a fresh set each year as the constant on/off wears it out.
    The only time it came off was at around 110mph, under 80 it is always rock solid.
    '10 R12RT, R90/6
    Suzuki DR 350
    Registered User tonyfr's Avatar
    Apr 2007
    SAT - LAX
    On one of my bikes, I use the Ram mount with the magnetic power plate base and the small piece of metal that attaches to the radar detector.
    SABMWRA MOA #62
    2005 BMW R1200RT
    1984 Kawasaki ZX750-E1 Turbo
    I'd guess that it's removing the detector often that causes the need for new velcro. Back when I used a detector it mostly lived on the bike, only coming off a couple times a year. I used standard stick-on velcro. The same velcro lasted at least 6 years, maybe longer. It was still OK when I stopped using the detector.
    May 2007
    Raleigh, NC
    Yes, that is it exactly. I use the same velcro for holding my MixIT amp under the seat. 5 years, good as new. But on/off 100 repetitions or so a year reduces the grip power a lot.
    '10 R12RT, R90/6
    Suzuki DR 350
    Aug 2010
    Salt Lake City
    Thanks for the feedback. It will be nice when the economy picks up and the police can get back to catching real criminals again. Oops, I started the rant! I promise though that is all I will say. For now. Without mentioning Michigan Troopers. Damn, ok I promise to stop ranting about 5 mph over tickets by Michigan Troopers in 3,2,1.
    Registered User Olsensan's Avatar
    May 2008
    Adirondaks and LI,NY
    I have the Escort 9500ix and I'm trying to figure out the best place to mount this. The bottom of the unit is not flat, rather it has a step in it. I have the accessory shelf but I am considering the mirror hole mount for the left side handlebar. Has anyone else got the 1150RT 02 with the 9500ix? where did you find the best placement and what product did you use? -G
    Braintree, MA
    Quote Originally Posted by Olsensan View Post
    Mine's in the tank bag. That effectively kills laser detection, but if you get hit with that, it's too late anyway. I rely on the audio through the Autocom. It works.
    -Tom (KA1TOX)
    May 2008
    Yes, if you are hit with laser, you're busted. Bottom line, don't lead the pack however, the unit will pick up laser scatter and that's the trick. Aside from taking the obvious precautions and being very alert. Have others used the mounts that rest on the handlebars or mirror holes?
    na1g
    May 2011
    Greater Bahstin, Massachusetts
    The most secure Velcro-type fastener is 3M's Dual-Lock. The two sides are identical and actually snap together. It's harder to find (Aerostich has it as do some auto parts stores). A warning, tho: it can be a bear to get apart if you use too much. I just use two strips of the industrial strength Velcro.
    pete
    May 2008
    Thanks for that info. I'm on the east coast, NY on Long Island. If I want to be a cheap-o, I heard that I can drive to the tolls at any of the bridges here and ask for the 3m strips. Someone wrote that they will let you grab a handful of those. If tomorrow is nice, I'll take a spin to the Throgs Neck Bridge and try it out.
