Page 1 of 12 1 2 3 11 ... LastLast
Results 1 to 15 of 170
Thread: New BMW Water-Cooled Boxer
    No longer a member here
    Apr 2006
    Pictures of the Engine castings, Courtesy of MO BMW Motorr?˝der
    Apr 2006
    Another one...
    Registered User boxwrench's Avatar
    Dec 2008
    Daytona Beach area,Florida
    Cool!
    like to see the whole assembly. Still can't affornd a newer boxer let alone this one.
    2000 R1100RT opal blue "Millenium Falcon"
    2006 Suzuki C50 Boulevard blue/silver w/ DJ drive mod.
    "Gator"
    Bluenoser
    Mar 2010
    Lethbridge Alberta
    The design is very similar to the older goldwings with the exception that the crossing tubes are cast in the block on the BMW & not external like on the wing.
    It will certainly add weight & make the bike more complex, but will result in more horsepower & longer engine life. Also better at meeting emission's etc, but will be more expensive.
    1999 R1100s
    Jun 2005
    Green Bay, WI
    Cool details, which do show connections which look like for water cooling. However, to me those views are not the "rear" and "top" views. To me, what is shown as the "front" view is actually the bottom of the crankcase, given the locations of the exhaust ports and what look to be the mounting lugs for the engine to the frame.
    What is shown as the "rear" view to me, seems to be the rear view but upside down, given the exahsut ports are shown on top. So far all other pictures of the "wet-head" show the exhaust ports coming out the bottom of the heads. In the "rear view" that hole in the center near the top, would probably be where the drive comes through for the oil pump?
    The "rear view" certainly does not look right for a connection to a transmission or a flywheel. But what is also interesting, is the views to me indicate the transmission will still be a separate case from the engine. that indicates it will still be a dry clutch as on past R's, and that the tranny will have its own oil supply. Those are both attributes I have always liked about the R-bikes.
    Calgary
    Oooooooh, the elusive wet-head.
    Ed Miller, Calgary, AB
    2008 K1200GT, 2009 F800GS
    I can't wait to retire and have a fixed income. The one I have now is always broke.
    Apr 2006
    Sorry for the confusion. The above picture shown as "front view" is actually the top view.
    The bottom view is this, here. Note that the intake is on top of the cylinders. not in the rear and the exhaust exits on the bottom.
    The rear view picture was cut off slightly by the scanner and the 90-degree bent tube on top is not shown.
    rabid reader dbrick's Avatar
    Santa Cruz CA
    I agree with AndyVH's assessment regarding the orientation of the second photo. The details on the heads in the two photos are consistent with this, and with a top-intake and bottom-exhaust configuration.
    David Brick
    Santa Cruz CA
    2007 R1200R
    Jun 2005
    Green Bay, WI
    AHA! I was a bit off, but it makes sense now. Yes, I agree with the bottom view now. Plus the bottom view shows what may be the locations for the cam chain tensioners. Also, the bottom view with a lack of mount lugs suggests the engine will be "hung" from the frame? Then what is shown as the front view actually being the top view shows where the oil fill hole will be on th RH side if the bike, which means the rear view is correct, and that causes more speculation to me. I may be wrong about the tranny being separate from the engine. That rear view looks to have journal positions for two tranny gearshafts.
    I wonder if this boxer will have a small diameter multi-plate wet-clutch driven right off the crankshaft like the cluth pack on the G450X? That may explain the large hole for the "flywheel/clutch basket", and it would correlate with the spy photos showing a left side swingarm on the new boxer. Hmmmm, the new boxer "may" be the first one with a wet-clutch? Starter on the rh side in the rear view through that hole by the recess? More hmm?
    Then we need to see the actual front view, because that is where the water pump, oil pump(s?) and ignition would have to be. Hmm again!
    Nov 2007
    Quote Originally Posted by ANDYVH View Post
    The rear view to me looks to have lots of machined recesses for bearings, I expect this to be the front of the transmission case and a multiplate wet clutch.
    It could also be for cam drive chains, counterbalancer, water/oil pump drive. etc. If that I hope it is the front view, so splitting engine from transmissionis not required to service these items.
    Jun 2005
    Green Bay, WI
    Good points all. But I think the bottom view clearly shows the galley for the cam chain on the left, plus the tensioner ports. Also, the rear view does not show openings where the cam chains would exit the barrels. Which would mean the cam chains are driven off the front of the engine. Also, there is some generous finning on the "barrels" and heads. To me that indicates the oil has some cooling chores still, and perhaps the radiator will be fairly small.
    Apr 2006
    Here you go. The front view was large and over 2 pages. A little difficult to scan. Now, don't kill the messenger.
    I can only say what they say. Cases are split vertically. Transmission and motor share a common case, clutch will be wet multiple plate cluch. Larger volume of combined crankcase and transmission will ease pumping effects. Cylinders are integrated into the block and the water jackets only reach up to the second cooling fin, that's why the extensive presence of fins.
    Sep 2007
    So. Calif.
    I have a K1600GT on "pre-order" but have more or less decided that I still prefer the R1200RT to the 16GT. So I'm curious as to what might replace the current RT.
    But I can't say I'm much enthused at the idea of carrying around another radiator and pump, coolant, and water hoses - I hope BMW will do something that gives this motor a little pizzazz. Maybe higher revs, better sound, lighter weight, more HP, etc. For me, lower emissions is not nearly enough. Sorry.
    '14 R1200GS,
    Priors: '13 K1600GT, '08 R1200RT, '04 R1150RT, '05 R1200GS, '73 R75/5.
    Mar 2008
    Camas Valley Oregon
    BMW'S great leap: BACKWARDS
    Marty - in the western Oregon mountains.'06RT, (gone '04RT, '86 Venture Royal, '81 Yamaha Virago920, '82Suzuki GS1100GK, '76 Suzuki GT750, Triumph 750 Bonneville, BSA Road Rocket 650, 61" Harley knucklehead)
    Nov 2007
    Let me be the first
    Which oil for the water cooled engine?
    Rod
