Results 1 to 15 of 22
Thread: Pinlock needs RainX ? Fog proof?
    johnnywishbone
    i'm going to order a schuberth c3 at the end of the week. i really don't know what to expect as far as the shield. are these things fog proof? if not, can i make it completely fog proof. my helmets are really old, so this is a big adventure for me. (i don't get out much.)
    i also made an appointment for glasses. the last time i rode at night, i had problems. besides, on my new rt, i can't read the display or the gps screen, unless i stop the bike and stick my head pretty close. this is not cool.
    i had a lot of boxer twins before, but the last twenty years , no, thirty, were on harley. having the new rt was like starting all over again. in the beginning, i was really depressed, but i'm starting to develop a love relationship with this bike. at first, the attraction was purely physical. simple animal lust. now, i'm feeling the inner beauty, touching the soul.
    this happened to me once before with my R100/7. we turned that bike into food one year.
    thanks for your time. jp
    Feb 2008
    Garland Tx.
    Johnny,
    I have the pin lock on my Shoei and I have never had it fog on me as long as the inner part is adjusted correctly.
    If you do get some fog, say on the left side then all you have to do it take out the inner part and rotate the pin lock a bit and reinstall the inner until it is sealed.
    Never been happier with it.
    Have fun with the new RT!!
    Mack McDonald
    Garland, Tx.
    04 1150 GSA
    +1 on PinLock. I have been using them on my Arai Profile for over a year. In addition to the 'no fog', you can get various coloring. The inserts are small enough that I carry all mine with me at all times. In a matter of seconds, I can go from really dark to clear to yellow, depending on the driving conditions. Haven't yet found much use for the orange or light tint. But if I ever do, they will be with me.
    Cheers,
    Jim R.
    Gear Up and Ride Safe
    Jim Rogers
    2010 R12GSA aka Heidi
    Yorktown, Va
    Registered User boxwrench's Avatar
    Dec 2008
    Daytona Beach area,Florida
    got it on my shoie multitek visor for my helmet. My glasses fog up not them.
    2000 R1100RT opal blue "Millenium Falcon"
    2006 Suzuki C50 Boulevard blue/silver w/ DJ drive mod.
    "Gator"
    Registered User boxerkuh's Avatar
    Carolina's
    Cool Pinlock no fog; glasses will fog
    Greetings... my 2 cents....
    Your pinlock should not fog up. I have been riding with a Shoei X-11 for 3 years with the pinlock. I do recommend changing the shields out every year to year and half.
    Now, as far your glasses, they might fog up from time to time. The only thing that I have found to work on the glasses is to crack the visor. I have not found anything "anti-fog" that really works... I have spend some money on different things but not really successful. My food for thought...
    Keep the rubber side down!!
    1986 R 80 RS
    1992 R 100 R
    BMW MOA Life member; Ironbutt Member; Airhead Member
    Pinlock shields are pretty much fog proof as long as you take care of them. Do NOT use anything other than mild soap and water on the inner removable liner. Using something like plexus or fogx on the insert will ruin it as some folks have found out. I remove the inner liner and wash in warm water with my fingers and some simple green then let it air dry before putting it back in the helmet. Plexus on the outside of the visor is fine.
    Some folks complain of extra glare at night with the pinlock. That hasn't been an issue for me with a pinlock in an Arai XD.
    Registered User WalterK75's Avatar
    Feb 2009
    Mississauga, Ontario
    I use the Pinlock also. The only time I find it fogs is when I've taken off the helmet and it is cold. For some reason it will fog up when I put it on. However, after a minute it clears and is fine. I think this is because the Pinlock is cold and one's hot, humid breath on it causes condensation and it takes a little time for the Pinlock to deal with it. I have several: dark, light grey. clear and yellow.
    Walter
    All government, of course, is against liberty.
    H. L. Mencken
    Registered User greypa's Avatar
    Apr 2011
    Newark, OH
    On the Arai helmets, is changing the inner shield to dark tint as good as changing the whole shield to dark tint? Hope this makes since. I'm thinking of getting an Arai and wonder if I should go with the pinlock and dark or a whole other shield. Any suggestions?
    Skip
    '82 R100
    '05 Stella
    Quote Originally Posted by greypa View Post
    Yes it is as effective. But it's more hassle to change the pinlock insert from clear to tint than to change the whole visor. So during cold weather I may start with the pinlock with a clear insert but when it warms up and the sun comes up, put on a tinted visor.
    Apr 2011
    Newark, OH
    Thanks Rockbottom. With all the negative talk about changing Arai shields I thought maybe the pinlock system would be easier.
    Skip
    '82 R100
    '05 Stella
    To change the pinlock you first have to remove the shield and pretty much flatten it out. If you don't do it that way you might get a ripple in the seal around the insert rendering it useless.
    My solution is to use a clear pinlock and change sunglass lenses as needed. I can switch between amber and green sunglass lenses faster than I can change the shield on my XD.
    It's a little tricky to learn to change an Arai visor but once you do, it takes maybe 20 seconds.
    Apr 2011
    Newark, OH
    I'll be in Geetysburg, PA. Wed, and New Holland on Thur. Going to stop by The Service Pavillion so I'm sure all my questions will be answered. Thanks for all the info.
    Skip
    '82 R100
    '05 Stella
    Heck, I'd pop down to Gettysburg and show you, but I have to drive to Connecticut tomorrow.
    Quote Originally Posted by rockbottom View Post
    Might depend upon which Arai. On my XD I have to unscrew 4 screws. It can sometimes take me longer than 20 seconds just to find an appropriate coin to do the unscrewing.
