Results 1 to 10 of 10
Thread: acc shelf Q
    the Wizard of Oz 26667's Avatar
    Jul 2006
    NW suburban chgo
    Question acc shelf Q
    So my R1100RT came w an accessory shelf with a couple chunks of velcro glued on. I use one for my I-Pass, but I'm thinking of bringing GPS on my summer trip.
    Here's my Q: I don't get how one mounts GPS to the shelf so that it's visible, and mounted sturdily enough to press the screen. Maybe I'm missing the obvious. It wouldn't be a first for me. The $100 gps unit my wife bought me, that we use in the car just has a little suction cup for the windshield. ( and I'm fairly certain I'm also looking at investing in a significantly more expensive, bike appropriate unit as well)
    Can you explain how aftermarket mounts work with shelf?
    thanx
    We might as well walk. ~ Adam Guettel The Light In The Piazza
    used to own: 1982 R100T, 1984 R65, 1986K75C, 1997 R1100RT, R850R, K75S, 1978 R100RS... what was I thinking?
    streetdoc
    Take a look at this for some options on a non-motorcycle GPS mount: http://forums.bmwmoa.org/showthread.php?t=52601
    Aug 2008
    North Carolina
    I bought an accessory shelf from RCU Designs for my 1150rt and mounted the shelf above the speedo assembly as per the instructions. The holes are predrilled and they line up exactly with the available holes already there. Once you have the shelf mounted you'll need a gps mount system. I bought mine at gpscity.com. You can choose your bike model and all the available mounts will show up. I bought a 2 hole base plate with a ball and the double socket arm for 1" balls that attaches directly to the base plate ball. You also need the adapter/holder cradle that fits your gps model.
    You'll mount the GPS unit into the cradle and then mount the cradle onto the upper end of the double socket arm and attach the lower end of the double socket arm to the ball on the base plate. Now the assembly of the GPS and it's mounting peices is complete.
    Now i should backup a bit. The base plate that you attach the double socket arm (that has the gps unit cradle attached to it) must be attached to the accessory shelf. To do this you will need to drill 2 holes that line up with the base plate (that has all the GPS peices mounted to it as described above). You can then attached your base plate (with the ball) directly to your accessory shelf.
    Once you have this setup in place the GPS will stay securely in place under almost any situation.
    Hope this helps
    Aug 2008
    North Carolina
    Also I have a Garmin 550 that is car/motorcycle specific but does not have the capabilities of the Zumo motorcycle series units. This unit works great for me. The main problem is there is no bluetooth or audio out jack to be able to hear the audio output. It is impossible to hear the driving instructions but you can see the map or the turn by turn directions. While this isn't nearly as efficient as hearing the directions it does work.
    The next GPS unit I buy will most likely be a Zumo series that can pipe the directions directly to my helmet via my Sena unit. After using the above described setup I think overall I would happier if I was able to actually hear the GPS directions.
    Jul 2006
    NW suburban chgo
    Thumbs up eureka!
    [QUOTE=brprider679;673995]
    That's what I couldn't figure out. I was thinking drilling was my last option.
    Thanx!
    Jul 2006
    NW suburban chgo
    Thumbs up cool
    Quote Originally Posted by streetdoc View Post
    hey, thanx! maybe I don't have to spend $700 on a new GPS unit. fact of the matter is that a lot of my trip will necessarily be on the slab anyway. To some degree, Im just thinking of the gps as a "time-waster" something to find which exit has which restaurants etc.
    Registered User ORCHARDRT's Avatar
    Jun 2005
    Nashville, IN Brown County
    I have an RCU shelf on my 1150RT and have mounted a number of things on the shelf. GPS Garmin V, 2610, thermometers ,Spot. It is great because it gets it up high so eye diversion is minimal. A cleaner mount (compared to the ram short arm) for the 2610 is to mount a 2x2 alum. angle on the shelf then bolt the gps bracket to the angle. It is far less messing around with the two balls and short clamp that has limited position and difficult to tighten and could tend to vibrate.
    Ben
    Check the RAM web site for the mount you need:
    http://www.ram-mount.com/Products/Mo...8/Default.aspx
    You can enter both your bike and the the GPS model.
    It looks like they have a mount for just about any GPS.
    Glenn
    2003 F650GS Dakar
    kayakncycle
    You can build your own with little expense
    My GT came with a Zumo mounted at the center of the handlebars. Thought it was too low for comfortable viewing. Even sketched a mount to be machinied from 6" 6061 T6 plate. I thought a mount tipped back at 15?? set on top of the dash shelf would fill my needs. Even cut out a piece of foam for a test.; good viewing and it misses the windscreen. Then on a trip to Home Depot I saw floor joist brackets for $1.89. I drilled four holes for the base and 4 holes in an AMPS pattern to fit the Zumo mount. Put in in the vice and rapped it twice with the rubber mallet. This gave me the 15??. Ground the corners to a pretty radius on the grinding wheel, scuffed it with a wire wheel, primed and a couple coats of enamal paint in a rattle can. You too can have a very robust mount for under $4.00 - stainless steel bolts and lock nuts will drive the cost up from the $2.00 bracket to nearly $4.00 when all done.
    My son's best tool in his box is a checkbook. I'm haven't evolved to that state yet.
    Dennis
    Jul 2006
    NW suburban chgo
    fun fun fun
    some humorous responses! Maybe you guys guys can advise further. i think I'm going to buy an Aqua Box from another MOA member to house my little garmin Nuvi. It looks like I could bolt their ball base to the acc shelf and then... ...I'm not sure what I'd need to purchase to connect between the ball base and the box. The Ram site is confusing and they don't list the 1100 in their compatibles. they only show the 1150 which has a different handlebar rig. I like the idea of fabbing a mount from the floor joists as above, but I'm not sure if I could attach the aq box. now we're havin' fun!!
