Results 1 to 15 of 27
Thread: Adding OEM TPM to R1200GS
    May 2007
    Flagstaff, AZ
    I just acquired a 2010 R1200GS 30th Anniversary. It has all the goodies except TPM (tire pressure monitor). From what I can tell, it sounds like bikes with the computer are already wired to accept the TPM signal; minus the wheel transmitters and the actual signal receiver module that plugs into the computer.
    Has anyone ever looked into adding the OEM TPM after the fact? Is this feasible/practical/cost effective?
    Ken
    "Striving to be less wrong than yesterday."
    May 2007
    Flagstaff, AZ
    Looks like it can't be done
    I received this response from my sales guy at the BMW dealer in Phoenix:
    Ken
    Unfortunately you can not add the BMW TPM after it has left the factory. You could on the 2009's but not on the 2010 or 2011. We have tried on a RT and spoken with other dealers that have tried on the GS. So if you want TPM you will most likely have to go with an after market system that does not display in the dash.
    Steve Bittner
    Sales Professional
    GO AZ Motorcycles
    sbittner@goaz.com
    (480)609-1800
    If anyone knows differently, I would love to hear about it. Alternatively, I'd love to hear your thoughts on the best after market TPM for a GS (Kisan, Orange, PressurePro, Stop & Go, others?)
    Ken
    Aug 2009
    Long Grove IL
    Can you do it on a 2009 R1200R?
    May 2007
    Flagstaff, AZ
    Based on the response I got from Steve at Go AZ BMW in Phoenix, it sounds like you can. Whether it's cost effective is another question.
    Ken
    Ponch ponch1's Avatar
    Dec 2010
    Fountain Hills AZ
    Quote Originally Posted by kencollier View Post
    Ken
    Steve Bittner
    Sales Professional
    GO AZ Motorcycles
    sbittner@goaz.com
    (480)609-1800
    I've heard you can't with an RT. Is this true? I'd like to have TPM on my 2009 RT.
    My Motorrad
    BMWMOA 162849 | BMWRA 41335 | VROC 8109-R | VBA 19
    Spring Lake NJ, USA
    You can't on any hexhead. The reason being - BMW won't sell you the enabling code needed to turn on the TPM in the instrument cluster. You can buy all the parts (at a rather high price..) but getting the code to make it work is impossible (I know several dealers who tried..)
    I'd suggest aftermarket. I'm trying a new one (so far I like it) from the UK. They don't have a US distributor (yet..) so it has to be ordered from the UK. Delivered price was under $175 - which is about what one TPM sender will cost from BMW for the factory system. This one is available with internally mounted sensors (they use a band type mount.)
    Here's the info on it:
    http://www.mobiletron.com.tw/b_eng_p...kindNo=S000032
    You can order it - sorta - here: https://www.tyre-track.net/
    I'd suggest contacting Hannah Whittle at: "Sales" - feel free to mention my name. Hannah was very helpful. I initially called her - then we conducted the rest of the business via email. Price was about what's shown on the website - with shipping costs replacing the VAT tax which isn't applied for items shipped to the US.
    I'm also looking at some others just out of general interest - but so far - the responses from the vendors has been very delayed and spotty, which doesn't give me a lot of confidence in their down-the-road support.
    Dec 2010
    Fountain Hills AZ
    Is it a liability issue? You can get ASC.
    My Motorrad
    May 2007
    Flagstaff, AZ
    ...I'd suggest aftermarket. I'm trying a new one (so far I like it) from the UK. They don't have a US distributor (yet..) so it has to be ordered from the UK. Delivered price was under $175 - which is about what one TPM sender will cost from BMW for the factory system. This one is available with internally mounted sensors (they use a band type mount.)...
    Don, Thanks for the tip. I like the looks of this unit compared to the others I've been looking at. The Kisan is a close 2nd. How frequently does it refresh its reading? Does it seem pretty close to real time? It looks like it's easy to install and doesn't interfere with your valve stems, which is a plus. Any option for changing temperature reading to fahrenheit?
    Ken
    Spring Lake NJ, USA
    IMHO - Kisan doesn't come close because of the requirement of mounting their sensors near the wheels. I know several people who tried, and returned the Kisan. Until they solve that problem - it's a non-starter for me. And the valve stem lumps won't work on many modern BMWs with the valve stem in a spoke - the lump will make part of it's first rotation and be knocked off by the brake caliper.
    Updates seem to be about 5 second intervals. They mention a rapid response mechanism, which I suspect does an immediate update based on rate of change of pressure (like a puncture.) You can change it to display PSI and F.. no big deal, the programming on it is REALLY simple (especially compared to some I've tried - which required running the bike in circles and stopping to try to have the head grab the ID of the sensor..) The sensors on this continually transmit - so on startup in the garage, I know what the pressures in the tires are.
    One thing a bit odd - in the owners manual they show the display hooked up to the bike battery for power. It has no on/off function on the display - meaning hooked up that way it would be on all the time (and drawing 65mA..) I put it to a switched circuit. Works fine that way.
    My display is mounted at the moment with velcro - the heavy duty stuff. I'll be making a bracket for it (the provided bar-bracket is nice, but I prefer it mounted differently..) to mount it to the bar-clamp bolts on my R12R (which have the BMW threaded ones used for the BMW GPS mount..)
    Haven't tried it in rain - but I saw no warnings about getting it wet so hopefully the display is water resistant. The display is very readable, and illuminated for night use (nice - the last one I had wasn't..) - just wish the background color was orange instead of blue..
    For the price - it seems a winner, but I only have about 6 hours use on it so far..
    Spring Lake NJ, USA
    Quote Originally Posted by Ponch1 View Post
    The reason you can get ASC is some police departments were making it a bid requirement - and BMW had bikes in stock without it that otherwise met the bid requirements. I think it's strictly a marketing decision. I can't see how allowing adding TPM would incur any liability that providing it from the factory wouldn't.
    Dec 2010
    Fountain Hills AZ
    Because a third party installed it. The dealer isn't the factory. If there isn't any liability, then why not sell it?
    My Motorrad
    May 2007
    Flagstaff, AZ
    The reply I got from my BMW dealer (above) makes it sound like it IS possible to add the BMW TPM to your 2009 RT. It's the 2010+ models that aren't possible. What I don't know is how much and how difficult. I imagine this is something you'd want a BMW shop to install.
    Ken
    Spring Lake NJ, USA
    That would be true for any BMW accessory the dealer added - like bags/racks/windshields/etc. I don't think the 3rd party is the problem - I think it's a German marketing decision trying to make it difficult to upgrade an existing bike, they'd rather you buy a new one I suspect.
    Spring Lake NJ, USA
    I would ask the dealer if they ever HAVE installed it on an '09..
    Jul 2005
    Colorado
    I looked into this several months ago for my '08 GT. Can't add the OEM TPM. I just finished installing the Doran system and it went on without a hitch. You may want to look into their offerings. Nice people and USA company, I believe.
