Results 1 to 8 of 8
Thread: K1300R- '09 oil change
    K1300R Alberta pholmes's Avatar
    Feb 2011
    Red Deer, Alberta, Canada
    Hey guys
    I'm a new member and new to BMW so please be patient!
    I have 1000k on my new 09 K1300R and decided to day to do a oil change today since the snow is melting (finally). I should have taken it to the dealer for its 1000k check up but thats a long way away and i wont be able to hit the highway till june at this rate missing valuable riding time! Figured what the hell, i do it on my car, what could go wrong!
    Anyway i drained the oil from the engine, removed the oil filter no problem.
    Whats getting me is the oil is not draining from the fill reservouir. The bike says its still full in the little level indicator pipe.
    I thought the oil should drain thru the engine but it seems to be hung up.
    Looking a little closer at the manual it says if the engine hasn't been used lately (and cold) it could get hung up in the sump.
    Any ideas?
    I could suck the oil out ot the reserviour but what then, if i cant refill and get the oil into the engine i'm pretty much screwed???
    Feb 2011
    K1300R (09) oil change
    Hey guys
    Any ideas?
    Jun 2007
    DIY section has it
    If you look in the DIY section of the Wedge forum, you will see how it is done on the K1300GT. It will be a tad simpler on your R. You can either let gravity drain it, a slow process I have read, or get an inexpensive hand pump setup or a Mighty-Vac style. The notes in Semper Fi's process are very good and include photos. You don't have the body work to deal with, and since you already did the filter, that part is not an issue. But read through his process and take what you need. You will feel safe and confident to complete your job.
    Jim Douglas '00 K1200RS >137,000 miles -- owned since new,
    '06 Kaw 650R track bike sold
    http://www.seagullbb.com/
    Daily Rider jurgen's Avatar
    Red Rocks
    Welcome to the MOA, but....
    Wrong forum - your bike is considered a "Wedge".
    The wedge forum has plenty of discussion on oil changes. Otherwise, Google is your friend, too.
    Best of luck!
    J?rgen
    Red Rocks
    04 R1150GS adv
    04 K1200RS last of the great bricks
    Sep 2006
    welcome pholmes,
    I am moving this to the Wedge Forum and combining with your post there and the DIY response from Jim
    For your answer, where the soda straw connects to the top of the oil tank is where you have to remove the hose. The drainplug only removes the oil in the sump of the engine
    You squeeze the black tabs together in that circle shaped ring and pull gently up . Then work the tube down past the tank to a drain pan...and walk away for a sandwich. It takes a bit to drain completely.
    I had my manual sitting here, but I must have moved it. It should give you a picture to go by.
    look in the gray title bar above next to the logo as well, I sent you a PM
    Steve Henson
    I suppose to enter a person would need the original bill of sale or really old title, or a Carfax. So, if this materializes folks need to know it will be a category before they leave home.
    Aug 2008
    Kingston, NH
    Quote Originally Posted by 58058D View Post
    Jim - thanks for the kind words - appreciate it.
    OIL CHANGE LINK HERE
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Jun 2007
    K1300S Minor differences - easier
    I just finished changing my oil basically following Semper Fi's DIY. It was cake. I used a $7 Fluid Oil Transfer* hand pump from NAPA putting their output poly hose on the 'sucking' side and pumped into my catch pan after following the sump drain and filter removal procedures. For the 1300S, the belly pan does not need to come of. The S pan does not cover the exhaust manifold so the drain plug is easily accessed. For the filter, the peg and stand attachments are all out of the way, though I used a 6" socket extension for the filter wrench, and deflected the top edge of the belly pan just ever so slightly. Everything else is the same.
    Thanks again Semper FI!
    *which it turns out is almost identical to the pumps that come with each gallon of shampoo and body wash we use at the Inn. All I really needed was to get the right diameter and length of poly tubing. I have a ton of these pumps if anyone wants one, send a PM
