Page 1 of 4 1 2 3 ... LastLast
Results 1 to 15 of 46
Thread: Drive Shaft U-Joint
    Pismo Beach, CA
    Drive Shaft U-Joint
    How could they possibly have ever maintained the Thousand Year Reich, if they weren't clever enough to make drive shaft U-joints REBUILD-ABLE?!?!?!?
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    Mar 2008
    DeLand Florida
    Same as the Brits when they manufactured a car with no replacement parts for the drive shaft, my old Ford Cortina.
    --Tony AnnapolisAirhead's Avatar
    May 2007
    Watkinsville, Georgia/Annapolis, Maryland
    Dang Lew, that thing is only 38 years old. Worn out already?
    1971 BMW R75/5 | 1975 Moto Guzzi 850T Cafe | 1983 BMW R100RS | 1988 BMW R100GS
    1988 BMW K75 | 1998 BWM R1100RT | 2000 Moto Guzzi Quota 1100ES |2002 Moto Guzzi V11 LeMans
    Registered User 88bmwjeff's Avatar
    Aug 2004
    Walnut Creek, CA
    I've heard of some people rebuilding the drive shafts. They ground away the tangs holding the u-joint in place, then tack welded the new ones in place. Finding someone to do this might be like finding a needle in a haystack. I think some people mentioned marine repair shops, but I have no first knowledge of this.
    Oh, and yes it's very disappointing (and detremental to the wallet) that drive shafts were not constructed to easily replace the U Joints
    Jeff in W.C.
    1988 R100 RT (the other woman)
    "I got my motorcycle jacket but I'm walking all the time." Joe Strummer
    May 2007
    Just curious how many fail versus the tinkering syndrome. I'm thinking not many, but that's not a good enough answer for the bloke on the side of the road with a failed one.
    What's the MTBF on them, anyone know?
    Pismo Beach, CA
    MY old Cortina... . 1966 Lotus MkI.. .. still kicking my a$$ for EVER selling it!!!
    Lew Morris
    1963 Dnepr
    Heartbeat of my R100GS Guenther's Avatar
    Jan 2007
    Colorado Springs, CO
    This is from a pretty new BMW (R100GS Yr, '88):
    ...at 67,000 miles. The sealed (!) bearings seized and split the metal claw which holds the bearings. At that time I was playing with the idea to have it repaired (e.g. http://www.brunos.us) but decided to go with a new one in the assumption that an OEM shaft is better balanced (wishful thinking!).
    /Guenther
    Quote Originally Posted by Guenther View Post
    /Guenther
    Most Airhead driveshafts go a very, very long time. R100GS driveshafts were designed wrong and often fail within 30,000 miles. In typical trim the deflection angles of the U joint exceeds the prudent deflection angle which puts stress on the U joint and they fail early. There are specialist shops that rebuild them with grease fittings. This helps but they still fail too soon because of the excessive deflection angles.
    Pismo Beach, CA
    Guess I'm a victim of statistics (like it's the first time.. . . )
    Quite a few show up on eBay, IBMR Market Place and so on, but you'll never know what ya got until it's in your hands.. . .
    But $615 for a new part. . . . ?!?!
    Lew Morris
    1963 Dnepr
    Mar 2008
    DeLand Florida
    Quote Originally Posted by Lmo1131 View Post
    If mine was a Lotus, I would be kicking myself too. However, mine wasn't. Just a 68 with slush box transmission. Bought it from a girl.
    Aug 2004
    Walnut Creek, CA
    I've often wondered which angle is too much. Is it at the tranny, at the final drive, or both. Just curious.
    Jeff in W.C.
    The angle at the front of the shaft is too great an angle. They fail there often. The interesting thing I have observed over the years is that the really big folks loaded for camping around the world have longer driveshaft life. But that heavy load squats the rear of the bike downward and straightens up the driveline angles. A short shock does the same thing.
    Ideally that shaft needs a CV joint but there really isn't room to use one - so they didn't. It's a wart. All models have at least one wart.
    Oct 2010
    Manley Hot Springs Alaska
    buy a spare
    Buy a spare on ebay.I did,and save it for a rainy day 100 to 150 cheap as a fix and this is the complete swing arm unit.
    May 2007
    /Guenther
    True enough, some of the GS bikes had issue but not that correlate to Lew's (the original poster) /5. sort of like comparing a Ford Pinto's horsepower to a real thoroughbred. They're both could be considered transportation...but completely different animals.
    I think most 247 swingarm driveshafts have a pretty darned good record. Just pack a tube of Compound-W and hope you never need to use it on your wart.
    Pismo Beach, CA
    ... just ranting... I've got a line on a replacement; odds are it will be in totally usable condition.
    That said, I bought a LWB swing arm/drive shaft last summer for a sidecar tug project. I hadn't touched it since getting it and thought that there is my new drive shaft!!! Serendipity!! WooHoooo
    When I broke it down, the U-joint was perfect, but some hack had completely buggered the threaded end by using a chisel to get the nut off; first land of thread was gone, the second and third set of threads were flattened by the nut going on slightly off .. . basically rendering it scrap.
    But hey!!! I do have a spare swing arm!!!
    AND IT WAS 83F here yesterday!!!!!
    Lew Morris
    1963 Dnepr
