Results 1 to 7 of 7
Thread: Headlight replacement; GT
    kayakncycle
    Need to replace low beam headlight on '07 GT. Read the RepRom procedure; remove right & left panels, windscreen, WS motor, Instrument panel, etc. etc. They did allow one to leave the rear trunk in place.
    Can I get to it, evenly blindly by leaving most of the plastic in place?. Previous bike was a Concours. Could change headlight bulbs without removing plastic. Hands would get beat up a bit. Always easier the 2nd time around.
    TIA -- Dennis
    Sep 2006
    I thought I watched a friend do one in the hotel parking lot as "easily" as the RT's. Maybe not?
    Luis has posted a DIY that may shed some light...pun intended!
    http://forums.bmwmoa.org/showthread.php?t=38866
    Steve Henson
    Aug 2008
    Kingston, NH
    Are you replacing the head light assembly or the bulb
    If you are removing the headlight assembly that is significant work
    If you replacing the bulb - go to the back of the panel and you will see an access door
    shown is the Xenon Bulb
    2009 G450X White
    IBA #35651
    Rogue Moderator
    Aug 2008
    Kingston, NH
    A couple more shots to provide perspective
    A little further out
    You can get to it - it is tight though, this is of course assuming you want to change your bulb and not the unit
    2009 G450X White
    IBA #35651
    Rogue Moderator
    kayakncycle
    Simple task completed Chapter 1
    Replacing headlight bulb on 2nd generation K1200GT: Standard (non-xenon) H7 lightbulbs.
    Sorry for the multi-post. System holds me to 156k file size.
    Attached Files Attached Files
    kayakncycle
    Simple task completed Chapter 2
    more picturres
    kayakncycle
    Simple task completed Chapter 3
    last set
