Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 35
Thread: Tires - Metzler Z8?
    Pennsy Flyer
    May 2010
    Southeast Pa.
    Tires - Metzler Z8?
    Has anyone seen or used the new Metzler Z8 tires yet? I have just recently found out about them and would love to try a set! Some of the online stores have them in stock but I don't know how long they have been available.
    AZ
    These are a major improvement over the Z6 if only because of a center sipe on the rear tire so you can now judge tire wear easily!
    Good luck with them and let us know how it goes.
    MOA #107139
    RA #28511
    YB #2005
    Spring Lake NJ, USA
    Rednick,
    I'm moving this over to "Gear" since it's more general - and these tires may be used on lots of BMW models. Hopefully you'll get some useful replies! I'm also adding the type of tire to the thread title - so that may draw some more interest.
    On the Road
    Jul 2009
    Holbrok Australia
    I've had one for a couple of months siting on the floor, will be fit fitted in a week or two, before next long trip. Hope it last longer than Z6 and M880 about 10.000km out of them always 2 up and lots of corners, was hoping M880 would last longer but dosen't look like it.
    http://www.metzelermoto.com/web/prod...8/default.page
    Kimberton,Pa.
    Yep..Z8's in M5 clothing. Getting a pair on this week
    Pennsy Flyer
    May 2010
    Southeast Pa.
    Z 8's
    Thanks for the input gang. I am sure they will be my next tire. I have always loved Metzler tires, never had a bad one! Can't wait to try them.
    Have a BRP trip in May and will need tires before that.
    Clay, let me know how you like them. I am in Elverson.
    Registered User tourunigo's Avatar
    Aug 2005
    Larry's River, Nova Scotia, Canada
    (K1100LT 1992) I have a Lasertec on the rear and need one for the front. Rear is almost new. What are the thoughts about putting a Z8 on the front with the Lasertec on the rear? - Bob
    Bob Weber
    saltyfogriders@gmail.com
    Larry's River, Nova Scotia, CANADA
    Apr 2010
    Mission, TX
    Z6 & z8
    I'm going to replace my front tire with the Z8 and leave the old Z6 rear on the bike for a while. The read on the new Z8 sounds good.
    Btw, I got 10,800 miles on the front (so far).
    tsp
    2010 R1200RT
    Kimberton,Pa.
    Quote Originally Posted by rednick View Post
    Just had 'em put on..in the 100 or so miles..very predictable even in the wet. So far a very confidence building tire. Again..I've only had 'em for a very short time. My Z6's that where removed had about 8k+ miles and the rear was about to show metal cords. These Z8's are in M5 clothing..so these new tires wont have the missing center wear bar issues that the Z6's had.. We'll see how the long these will wear in retrospective..
    Apr 2007
    Buffalo Grove IL
    Are these a "Dual Compound" tire?
    Sorry for my ignorance.
    Kimberton,Pa.
    Metzeler's all-new Roadtec Z8 Interact‘šů sport-touring motorcycle tyre is now ready for the highways and mountain roads with several much appreciated advances including its Greek Pi (π) tread pattern, new contoured profiles and nano-scale compound solutions matched to a well-proven Interact‘šů: Multi Zone Tension technology structure for performances from the first mile, at full-load and in all weather conditions. The combination of these features make Roadtec Z8 Interact‘šů the perfect tyre for modern Sport Touring needs, dedicated to riders making long-distance journeys and to devoted all-season sport riders with reliability and riding easiness to enjoy the distance, safely.
    Easy riding for maximum enjoyment
    Metzeler's new Roadtec Z8 Interact‘šů is yet another class-leading tyre committed to riding enjoyment, that is, a tyre with versatility of use, comfort and safety (especially under wet conditions) that permits you to focus on the ride. Roadtec Z8 Interact‘šů provides increased riding enjoyment initially through a new generation CMT (Contour Modeling Technology) profile that reduces push steering force by 5% versus its predecessor, immediately elevating the overall handling capabilities and easiness of various bike setups. This was achieved through a reduced cap section height, resulting in a more rounded curvature design to improve handling and increased stability. Although the profile has measurably quicker steering transitions, an incredible safety feeling is still present through a predictable turn-in rate that adds confidence to challenging riding such as panic situations on the wet while braking or low-speed turns on mountain passes.
    Additional elements of riding enjoyment like excellent handling, stability and reduced road noise are attained by mating this tyre profile to the latest structural innovation: Interact‘šů multi zone tension technology, along with a functional tread pattern and temperature resistant compounds. A final footprint area 8% wider as compared to the Roadtec Z6 Interact‘šů is the outcome of a variation of steel belt tensions and a strategically placed tread pattern which optimizes pressures in the footprint area.
    Apr 2007
    Buffalo Grove IL
    I had seen that on the Metzler site. Just can't get the dual part....
    Registered User realworld51's Avatar
    Mar 2011
    Canton, MI USA
    Quote Originally Posted by OU812 View Post
    Reading further, it appears they use differing belt tensions in the tire carcass rather than zoned tread compound texture. This from the Technology tab:
    "Interact‘šů Technology‘«÷s new scheme with a 3 zone tension (see image) provide a comfort and mileage for sport-touring, in order to enjoy the distance, safely:
    High steel belts winding tension in the center reduces compound movement and increases stability of the footprint area which reduces wear and ensures high speed stability on long motorway journeys (centre zone - 2).
    Low steel belts winding tension creates more flexibility and therefore higher energy absorption, the compound increases the temperature and in a way becomes softer offering more grip while leaning. (Shoulder zones - 1 & 3)"
    Reference is made on the Versatility tab to tread compounds that differ between the front and rear tires, but not zoned within each tire.
    Steve W
    Canton, MI USA
    2012 K 1600 GT (from 8/6/2011)
    Pennsy Flyer
    May 2010
    Southeast Pa.
    mounted my new Z8's Thursday night after work. have about 350 miles on them now, maybe 45 or 50 in the rain and I love em! such a huge improvement over the PR2's I took off.
    leaving on a trip to the BRP ,Smokey Mtn's, Etc in 2 weeks so I will report back after that ride.
    Apr 2007
    Buffalo Grove IL
    Thanks Steve!
    I think these tires will be my next.
    Steve
