Results 16 to 28 of 28
Thread: Camp Cooking Burners
    GREGFUESS
    Whew, lots of choices. I like the simplicity of the Coleman Exponent Multi Fuel, since you can use fuel from the motorcycle gas tank. But there is a lot of discussion in the reviews about the need to do maintenance (primarily cleaning the burners). This doesn't sound like fun while out camping. Of course the reviews indicate that if you use white gas this maintenance issue is eliminated, since white gas is supposed to burn cleaner.
    Anyone with this type of burner, how much maintenance is required if you use unleaded gas in these units? How much trouble is it?
    The MSR options require a larger, though refillable fuel tank, but that seems would take up more space than I would like to give up. The refill option is attractive for several reasons. But the Coleman tank is refillable, too.
    I do not like the idea of throwing away consumed fuel tanks, not to mention the cost of that fuel.
    Am I on the right track? Appreciate all the information.
    Raspberry waffles Bob!!! kewlmoose's Avatar
    SE Wisconsin
    The exponent's tank holds enough fuel to get me through most trips without having to siphon fuel from the RT. I have burned gas from the bike a couple of times and then went back to white gas without any issues. I do clean the stove in the fall/early winter when I put my gear into storage. Not much time or effort required.
    82 R65LS - gone but not forgotten
    02 R1150RT
    "Oh good, my dog found the chainsaw"
    "I finally got my head together, now my body is falling apart."
  3. 03-23-2011, 06:56 PM
  4. #18
    Pismo Beach, CA
    The presumably now-obsolete Optimus 8R stove
    I was wondering if someone would mention that old, and still thoroughly functional, stove.
    Now known as the Hiker+
    I still have mine; totally K.I.S.S. (which fits my personality)
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
  5. #19
    Port St. Lucie, FL
    The MSR stove needs a clean/rebuild every several years. The small MSR bottle (about a pint) usually lasted me a day--2 hot meals and a hot snack. I still like the ability to tap the bike's gas supply instead of carrying disposable cannisters.
    I used a Jet-boil for a few trips and gave up on it because I was either out or fuel, or had to buy a big propane cannister. Supply of the Jet-Boil cans is not readily available. However, when it worked, it was great--I now use it on 1 or 2 day trips, and use the MSR on longer adventures.
    The old US Army primus gas stoves are still the best, but people now want Antique Collector prices for them. My uncle carried one all through Europe in WW 2. When he came home he gave it to me and I used it regularly until about 1980 when it was stolen from my campsite.
    I hope the guy that stole it had it blow up in his face.
  6. #20
    GREGFUESS
    Hey, now that is a nice setup. Very much along the lines of what I am looking for. Does the burner need to be cleaned regularly, like daily or something?
  7. #21
    It has moving parts, so partially K.I.S.S.
    The pump was an add-on option for the old 8R. Without it getting the burner started on a cold morning could be interesting.
    For totally K.I.S.S I'll stick with my alcohol burner even though it does mean I need to carry some denatured alcohol.
  8. #22
    Quanto12
    I have the Brunton Nova mutifuel stove,now called Optimus Nova I believe. The stove was built for hard backpacking,at high altitude!This thing will burn camp fuel, gasoline,diesel, jet fuel,...etc! It will withstand realy high winds compared to other stove,and is easily ajustable from simmerring to hard boilling to do any type of cooking!
    Canister type stove don't work great at high altitude or when it's colder,sometimes won't even turn on at all, but are cleaner,and you can get some that are very compact!
    When I bought the stove about 9 years ago for backpacking,pretty much every different manufacturer always suggested to use regular camp fuel in these stove as the primary but if you were stuck,you could use other type of fuel for back up!The main reason,was that the later type of fuel would be hard on the stove or clog up the system faster,and the stove wouldn't work to it's full potential.But from what I read here maybe it's not that bad!
    One thing to remember is that some fuel burns hotter than others,so if you use different type than what it was tested with you might not get the same results as the manufacturer's!
    All the brands that are mentioned in this forum are all excellent stoves! The one I have is pricier,but i wanted one that I can use in any situation,and at that time it was voted as one of the best by Backpacker magazine!
    Sorry for the long story,Good Luck with your choice!
  9. 03-24-2011, 03:24 AM
  10. #23
    GREGFUESS
    Quote Originally Posted by PT9766 View Post
    No, the Optimus 8R has a built in needle to clean the jet. You simply turn the knob which controls the burning rate and therefore the amount of heat generated past the full open position to the "clean" position and it raises the needle to clean the jet.
    PT9766
    Now, I am confused. I visited the Optimus website, and cannot find the 8R. They do have the Hiker+, is that the same thing? The Hiker+ burns all kinds of fuel, but they do not mention the needle you describe.
    Can you clarify the 8R reference? Thanks,
  11. #24
    Registered User stanley83's Avatar
    Oct 2009
    Somerville, MA
    Quote Originally Posted by gregfuess View Post
    Field maintenance usually isn't an issue, but if it's needed it's relatively simple and usually consists of cleaning out the jet with a needle (use the one provided by the manufacturer). Some stoves have the cleaning needle built in.
    Usually not much trouble trouble, at worst using the needle before lighting and after done.
    MSR liquid fuel stoves are sold separately from their fuel bottle and you have the option of using bottles from 11oz. to 33oz. This also allows you to pack the parts separately.
    Stoves with tanks under the burner preclude the use of the Outback Oven, if this is an issue,
    -- Justin
  12. 03-24-2011, 12:20 PM
  13. #25
    Oct 2009
    Somerville, MA
    The 8R has been modified for multi-fuel and renamed the Hiker+. The box is black, not blue, the fuel tank is painted green, not brass and the pressure pump is standard, but otherwise the same classic stove. I see they also still sell the Svea, another classic. I have '70s versions both these stoves and they work as new, nothing like tested technology.
  14. 03-25-2011, 06:26 PM
  15. 03-25-2011, 06:33 PM
  16. 03-25-2011, 07:33 PM
  17. #26
    Slow & Easy
    Dec 2005
    Austin, Tx
    REI right now has a one time 20% off coupon for any full price purchase for members. They have other stoves but, I bought the Coleman 442 feather exponet(multifuel unleaded or white gas). Full purchase price is $79.95 minus $15.99(20%) = $69.24. I also had a rebate for 2010 purchases taking off another $46.66. My out the door price because I had the rebate was $22.58. If you are an REI member now is a good time.
  18. #27
    Svea Mountain Stove
    I have heard people talk about camp stoves of burners that use gasoline as fuel. The ease of carting gasoline in the bike's tank, and the basically endless supply of it in the tank, makes this sound like an attractive option for cooking. I have been using an iso burner that is compact, but that requires cannisters of fuel, which is definitely places the fuel in limited in supply and in bulky containers.
    If you use a gasoline powered burner, can you share what brand and model you are using, and what you would use now if you had it to do over again? All comments and recommendations welcome.
    http://www.auctionbandits.com/galler...ety-stove.html
    Svea 123- had mine since 1983. Several harsh winters in Germany, works like a champ.
  19. 04-07-2011, 12:14 PM
  20. #28
    Jun 2007
    Portsmouth, NH
    I have an MSR XGK-EX. It a multi-fuel stove that will run on gas, jet fuel etc. It's reliable enough and would be the perfect stove for melting gallons of ice or cooking anything really fast. It is not terribly subtle for anything that needs simmering. It would also tends to convince the folks at the next camp site that you are cooking with an F-18 on full afterburners.
    At some point I will probably replace it with a butane stove as I understand they are a bit less intense.
