Results 1 to 4 of 4
Thread: Clutch cable replacement: Hassle or not?
    Brookfied WI
    Question Clutch cable replacement: Hassle or not?
    I have to replace the clutch cable on my 1985 K100RS.
    I know I have to take the gas tank off but as far as the rest of it goes, is it fairly straight forward to replace this?
    Thanks!
    Blocking the slow lane
    Edwardsville, IL
    Yes, its pretty straightforward once the gas tank is off. Are you still on the original cable?
    Jon Diaz
    BMW K75/K12GT
    BMWMOA Ambassador
    Brookfied WI
    Talking Done! Simple (once you know how!)
    Just finished the cable install.
    Pretty straighforward with the exception of trying to get the little rubber boot throught the middle of the bike. I used a pencil to help push it through the tough places.
    Bike works fine...just like Willie Nelson, we're "On the road again."
    Have bike, will travel lancew's Avatar
    Central VA
    the pivot on the clutch lever assembly wore on my '85 and allowed some play between the lever and the bar. I wound up breaking 3 cables in just over several months, right where the cable meets the lever. (sorry, can't remember exactly which part of the assembly was worn).
    If it happens again, you can just wrap the bottom of the old cable TIGHTLY to the top of the new one and pull it right up through. Wrapping the boot will solve that problem too. Faster than removing the tank.
    If your old one broke right where the cable meets the brass thingy, you might want to be ready with a new assembly, a new cable, and some black tape! good luck
