Results 1 to 15 of 24
Thread: not sure what to do
Hybrid View
    not sure what to do
    I'm in a bit of a quandry. I have a 76 r90 that I bought thinking this would be the bike I could crisscross America on while making yearly reliability and comfort improvements. Sort of like the Breakfast 101 story in the current ON-I love that story!
    After a 1700 mile trip last summer, it became obvious that future trips will not be happening until/unless I am able to resolve the bike's handling issues pertaining to grooved roads. I can't be calling every state's DOT and ask whether my planned route has grooved roads on it. I know the various techniques for riding on such surfaces, but I'm telling you it is downright frightening and I grew up riding dirt bikes in snow, gravel, etc, so I'm hardly a novice when it comes to handling bikes on various terrains.
    What don't want to do is sink a bunch of money into the bike only to find to find the issue is only slightly improved. I know there are fork braces, swing arm braces, suspension changes and tire changes available, but am real reluctant to go down that road without hearing from others that such expenses are well worthwhile.
    If I didn't have this problem, I'd be looking to get a custom seat and some different handlebars this year.
    Right now I'm running year-old Michelins and the front tire has a groove right down the middle.. I'd be willing to sacrifice that tire for another if others can attest to such a move and recommend a specific tire.
    Should I just accept the bike for what it is and get something else or there reasonable changes that could make a world of difference.
    Well, obviously you need to ensure that the bike is set up mechanically correctly and that you're running the proper pressure. I think the first thing to do is to address the front tire. A groove down the middle strongly contributes this problem. As this past post indicates, the narrow front tire only makes it worse.
    http://forums.bmwmoa.org/showpost.ph...9&postcount=11
    More info here:
    http://forums.bmwmoa.org/showpost.ph...06&postcount=9
    I think that's the easiest first thing to do.
    Aug 2006
    Lawrence, KS
    I've had good luck with Dunlop 491 and 404's. Neither tire has a continuous groove running around the tire. That seems to make a lot of difference. The worst rain grooves always seem to occur in multi-lane congested traffic. I hate that, "I'm not really steering this bike feeling"
    John Kuhn MOA#83073
    R1100S, R100S, Honda VFR
    Assuming the bike is in OK mechanical condition the root cause is the flex in the small diameter forks, when the grooves in the tire try to follow the ridges/grooves in the pavement.
    The two direct attacks to minimize the problem are a fork brace and a front tire without circumferential grooves. My candidate would be a bias ply Metzeler 880 front tire if the 100/90-18 will fit instead of the original 90/90-18. There are others.
    You might still notice some steering oscillation but it should be less than frightening.
    This of course assumes:
    Sound swingarm bearings and adjustment.
    Decent rear shocks.
    Sound and properly adjusted steering head bearings.
    Good wheel bearings.
    Good forks, not worn, (with oil preferred. )
    By the way, if milled pavement is exciting don't try steel grate bridges, especially those with a diamond grate pattern.
    Pismo Beach, CA
    +1 on the front tire replacement.
    I had all kinds of low speed wobble issues and after much tweeking of fork stem bearings, aligning of sliders, etc. it came down to the front tire being OLD... it was a low mileage Continental RB2, but it was old... and no longer compliant. I replaced both of mine with Bridgestone S11 Spitfires... completely new bike, no wobbles, no "hunting" on rain grooves, etc.
    You could do a search of past "tire" discussions and totally overload your head on which ones would work the best; like this one for example... But I would bet a Pfennig that just about any brand new tire(s) would solve your initial problem. Cheapest route right now; replace the front tire.
    That said... perform the requisite mechanical checks; steering head tightness, or is there any "notchy" feel when you turn the forks? Have you checked/drained/refilled the front forks?
    These are still great bikes. But they're old and need to be regularly maintained, and maybe more importantly, understood.
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    --Tony AnnapolisAirhead's Avatar
    May 2007
    Watkinsville, Georgia/Annapolis, Maryland
    +1 on the Bridgestone S11 Spitfires (and a great value).
    Another option is Avon RoadRiders, that come in proper sizes for Airheads. The folks I know that have them swear by them and the tread design doesn't have said grooves down the middle. That would concern me too.
    1971 BMW R75/5 | 1975 Moto Guzzi 850T Cafe | 1983 BMW R100RS | 1988 BMW R100GS
    1988 BMW K75 | 1998 BWM R1100RT | 2000 Moto Guzzi Quota 1100ES |2002 Moto Guzzi V11 LeMans
    dealer recommendation
    Went to our local dealer to get his thoughts-he recommended Metzlers-I forget which model. When the weather improves, I'll spring for some tires. He assured me it will make a big difference-said in fact that even some modern bikes have that same problem.
    If that doesn't work, I guess I'll get something else.
    Thanks to all that have replied.
    Chuck
    May 2007
    As others have said, there are a lot of things the add up to the sum of a good suspension. Its great to have multiple minds on it--nobody is as smart as all of us.
    I do think that any tire with a groove up the middle can't help in the situation like you describe. While I do like the S11 Spitfires, they too have said groove...as do the Metzlers (Lasertecs, not Marathons). Prior to my S11 switch, I had Metzler Marathons and they did not have a groove in the center. They last a loooong time as least in my case but lack in the grip department compared to the S11 and from what I've heard about the Avon RoadRiders.
    I think the S11 Spitfires are very similar to the Lasertec's, but a far better price point. They have a good rep for wet road handling, longevity and are plenty sticky on dry pavement. Snowbum had a good write-up on them as one of his favs. You can pick them up for $55-75. Lasertecs, not so much. The Avon RoadRiders are a bit more perf oriented and priced accordingly.
    lowkey
    I have had a similar problem with other bikes (front end following rain groves), the fix is to change tires and raise air pressure. I always run the pressure in my tires right at the limit recommended by the tire manufacturer.
    Good advise about the amount of weight on the rear of the bike too. The farther forward (and lower to the ground) the load is the better the bike will track.
    My 78 R100S had ancient, hard Conti's on it when I bought it and handled like a turd. I wanted a vintage look so I put Dunlop K70's on and I really like the way it handles now. Tracks like it is on rails on the freeway and seems to stick real well on the curves.
    Quote Originally Posted by lowkey View Post
    If you are talking about that "max pressure cold" label on the side, that is NOT the pressure you should be running at on a regular basis. That is "2 up, carrying all but the kitchen sink" pressure. you actually get slightly poorer tire life, and you definitely compromise handling.
    however; your bike, your choice.
    That's right. By increasing the pressure, you reduce the tire-road contact patch. All the power now has to go through this smaller patch, thus wearing it out faster. Not to mention less surface area for heat transfer. Stiffer sidewall due to higher pressures and smaller contact patch...also contribute to compromised handling.
    lowkey
    Well, I am not exactly a light guy. I really don't care if I get a few extra miles out of a tire, although I seem to be getting about what others seem to get out of similar tires.
    While I don't claim to be an expert I DO have some experience (21 years in the motorcycle business and riding for 44 years). What I have found over time is that generally speaking, the closer to max tire pressure (within 5% or less) I keep my tires the better my bikes seem to handle.
    Of course YMMV.
    P.S Most of the bikes that I have dealt with that had handling issues or odd tire wear problems almost always had low tire pressure when I checked. Some of them were as close as within 15% (40 PSI recommended max but down to 32), when I raised the pressure the wobble went away. Some of this is obviously the individual tire characteristics, but generally I'll stick with my statement. check tire pressure and go for a test ride before you start disassembling your bike.
    And one more thing........wasn't the OP talking about being on a trip, which would imply that the bike was loaded down?
