Results 1 to 10 of 10
Thread: Newer Oilhead Brake Light Enhancements
    I have read that BMW does not authorize any brake light enhancements on bikes with the new integrated brakes, and yet I think some folks are using Hyperlites. Is this a problem? I also know that there is a "back off" option with Lite Buddies that flashes the running lights when the brakes are applied. Since the power for the lights comes from the tail light, the power demand for the flasher must be small. Would this be a problem with the new brakes?
    Frank G.
    Hattiesburg, Mississippi
    2004 R1150RT
    Chambersburg Pa.
    Brake lights
    The service manager at my dealer told me not to put anything of that nature on the bike. He said he has seen several newer (integrated brake) bikes that developed numerous ABS fault indications when these mods were installed. However, I have heard from folks that the flashing LED devices have worked seccessfully, because they draw so little power.
    I have met the enemy, and he is us
    2011 R 1200 RT
    prhkgh
    False "light out" w/brake light flasher...
    I expect this has been asked and answered before, but I couldn't find it in the archives...yet this thread is close, so here goes.
    I had a 'brake light flasher' installed on my 2000 R1100RT without any problem. Don't remember where I got it, a round blue sealed relay that makes the brakes flash 3 or 4 times before going steady...and if brakes reapplied a few moments later the flashing is of shorter duration.
    Worked great. Liked it. Got a new bike, a 2000 R1150RT-P. Moved the flasher over. Now the 1st time I hit the brakes I get what I think is a "bulb out" idiot light on the dashboard (light right under the flashing ABS test light.)
    Everything seems to work fine, but I don't like riding with a false lamp out error.
    Any suggestions? Do I need a 'special' flasher to avoid this? Maybe I need to wire up a resistor ahead of the relay so whatever is sensing things sees a heavier load when the flasher is cycling the brake light off?
    Suggestions welcomed. Thanks, Paul
    MyPetersahn mypetersahn's Avatar
    Nov 2008
    Murfreesboro, TN
    I had HyperLites on my 94 K1100LT and no problems. I had the 8 LED running/flashing brake lights on my 2004 1150RT with no problems as well. However, I did have one of the LED modules crap out recently. Called HyperLite and they immediately asked me what model I had and said they'd send me a new set--no questions asked. Great customer service.
    Since I was going to replace the existing set on the RT, I upgraded to the 16 LED 3 way, running/brake/turn model and added another set of 8 LED running/brake for a double setup. Just installed both last week and all works fine. HyperLite let me pay for the difference in the original cost of my crapped out 8 LED set and the new 3 way set. Whole shipment arrived within 2 days!
    Again, kudos to HyperLites and highly recommend the products.
    Jeff Peterson
    Murfreesboro, TN
    R1200RT
    MOA#91237, IBA#40505,
    Registered User boxwrench's Avatar
    Dec 2008
    Daytona Beach area,Florida
    I just installed 16 led hyper lights and signal minder ( w/ the brake lite option installed)at the same tiime.
    works ok.
    just kinda wierd seeing all 4 sigs flash a few times. and having the the rear ambers on all the time ( legal in Florida).
    2000 R1100RT opal blue "Millenium Falcon"
    2006 Suzuki C50 Boulevard blue/silver w/ DJ drive mod.
    "Gator"
    Sep 2006
    have hyper lites on three oilheads and run-n- lites on another, also the kissan signal minder on all that as mentioned turn the signals into runing lights.
    Never any issues with warning lights
    Steve Henson
    On the Road
    Aug 2005
    Wisconsin
    Go to Bob's BMW, they advertize systems that will work on all BMW. I have the Brake! option on my 2000RS with no problems.
    On a seperate note, for Henzilla, where did you find the Reddy Kilowat symbol?
    Just north of Seattle, WA
    Quote Originally Posted by Mr. Frank View Post
    What years do you consider a "newer Oilhead"?
    Seattle, WA
    2012 R1200GSA
    2002 R1150RT-P
    1992 K75S sold
    South Carolina
    any bike with the Canbus system can be a problem, or so I've heard. I have a Knight Rider brake light on my 99 RT with no problems. I also have Hyper lights that hook straight into my taillight plugs. I spliced the Knight Rider light into my tail/brake light wires. If you Google Knight Rider Light, you'll see what I have...
    South Carolina
    PS the light I have is sold by Custom Dynamics for $ 26.95 Ea.
