Results 1 to 4 of 4
Thread: Skene P3 Flasher Mode When Off
    Apr 2010
    Mission, TX
    Is there a way to wire the P3 controller so that the flasher mode still works after turning the key off like the standard 4 way flashers work on the 2010 R1200RT?
    Currently I have the P3 wired thru a Fuzebloack that is triggered thru the front marker light.
    TIA,
    tsp
    2010 R1200RT
    John. jstrube's Avatar
    Nov 2009
    Atwater, CA
    Yes, I believe it has this feature, but you have to wire up the P3 to the battery to make it work that way. Since yours is switched, it will not work unless you rewire it. The instructions will tell you how to use it in flasher mode with the key off.
    Apr 2010
    Mission, TX
    Parking Light Option
    The trick to doing this (assuming you trigger your LEDs from the front parking lights) is to turn your front parking lights on. This can be done by switching your turn signal on and holding it immediately after turning off the bike. Your front parking lights and tail light will turn on and remain on.
    HTH,
    tsp
    Quote Originally Posted by tsperez View Post
    TIA,
    tsp
    2010 R1200RT
    Sep 2007
    Virginia
    On non-'RT models you can simply wire the P3 Lights controller to the tail light, as this also comes on when the parking lights are turned on.
    __________________________________________________ ____
    Motorcycle Visibility Lighting systems: Can You See Me Now?
