Results 1 to 5 of 5
Thread: How To Mount Nuvi 500 to RCU Tray???
    Aug 2008
    North Carolina
    Does anyone have any ideas on how to mount a Nuvi 500/550 to a RCU accessory tray? I need some specific application advice if possible from someone who has successfully done this.
    Registered User tonyfr's Avatar
    Apr 2007
    SAT - LAX
    What model bike? If you are mounting on a R1200RT, I wouldn't use a RCU shelf. I had one and it tends to bounce around a lot on medium to rough roads. I would use a Migsel and RAM mounts.
    SABMWRA MOA #62
    2005 BMW R1200RT
    1984 Kawasaki ZX750-E1 Turbo
    Aug 2008
    North Carolina
    r1150rt. I looked at the Migsell but they don't offer anything that fits a Nuvi. Only the Zumo.
    Tame Racing Driver Stig's Avatar
    Dec 2009
    Hudson Valley, NY
    The Migsel mount simply attaches to the top of the dash above the gauges and provides a base to attach any RAM ball mount. To mount a Nuvi all you need is the RAM Nuvi cradle and a 1" connecting arm. You can use any length arm as long as it fits the ball mount, but I found that the longer arm length produces more vibration.
    Craig
    New York's Hudson Valley Region
    2009 R1200RT
    MOA #146131 IBA #55715
    Touring Panpsychist Theo's Avatar
    Apr 2010
    Western MA
    brprider -
    I wouldn't purchase a shelf just for the Nuvi 500. I went through all this when mounting my Nuvi 550. My criteria were:
    1. mounting as close to my line of sight as possible;
    2. ease of removal;
    3. rock-solid mounting.
    Initially, none of the solutions I researched met my slant on the three criteria. However, this past summer, I attended the BMWRA rally in VT and saw the following Wunderlich Navigator mount (all stock photos):
    Here it is mounted above the instrument cluster:
    And the view from the front of the bike:
    It mounts onto the existing hardware so no drilling is required. The faceplate can be adjusted to pivot up and down and is pre-drilled to accept just about any GPS cradle made. I purchased the Garmin Universal Mounting Cradle/Wiring kit which included the wiring and a very nice cradle that holds the Nuvi securely, but makes removal a snap:
    The cradle also has a receptacle to protect and hold the power plug when not connected to the Nuvi. Obviously, I did not use the RAM ball mount.
    IMHO, this Nuvi 5xx mounting system works very well and, should I wander into the Zumo 220 world (for the bluetooth audio), it will be a perfect fit for that unit as well. Of course, if you have other accessories that need mounting on the shelf, this may not work for you. In that case, I have heard terrific things about the BMR Co-Pilot system.
    Theo
    2009 R1200RT, 2007 Shadow Aero 750 (sold)
    2012 MINI Countryman S, 2004 MINI Cooper S JCW, 2000 BMW 328i
