Results 16 to 23 of 23
Thread: Broken Zipper
    Jun 2008
    St. Petersburg, FL
    There used to be a place in the mid west around Chicago called, I think, Dr. Zipper. they would replace your zipper and/or add a three inch extension via two zippers to your leather jacket.
    Don't know if they are still in business but I think I saw an ad for them in Rider magazine last year.
    I used them about 10 years ago to replace the zipper on my Heine Gerike Paris to Dakar jacket.
    AGS
    Pismo Beach, CA
    Sometimes your slider gets out of whack.
    I know I hates it when my slider gets out of whack...
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    DrCiao
    Hey Lmo1131, what was the name of the sailing place that did your jacket? Was it actually in Pismo?
    Kbiker BCKRider's Avatar
    Jan 2009
    B.C. Canada
    Bob Weis (post #6) gave some GREAT advice. Maybe he can elaborate and "zippers" become a sticky in this forum. We all have more plastic zippers than we can count. Maybe he (or you) can answer my first question: what common products contain silicone for cleaning and "greasing" zippers? Most of these automotive products don't list ingredients. Is WD40 good? I've been using something called "Eagle One Protectant" with good results, but you probably wouldn't find it in the US.
    If you have a zipper that starts then separates, here is my addition to Bob Weis' advice: After cleaning and lubing the zipper, make sure the slider is all the way down then insert the little metal tab all the way and zip up only a couple inches. If the zipper separate, un-zip pulling gently on alternate sides. Take a very close look at the gap in the slider where it meets the gap in the little metal gizmo at the bottom. If it is wider, THIS is what you want to gently squeeze with a needle nose plier. When that gap is identical, the zipper should work, assuming something else hasn't been wrecked.
    Worked for me on a very nice rain jacket which hasn't zipped for over a year. God, I love this forum!
    Doug
    1992 K100RS
    Yarddog
    Quote Originally Posted by DrCiao View Post
    Are we doing metal or plastic zippers? Metal will scratch the paint?
    I found a local shop that wants $45 to do the zipper. That's not including the zipper itself.
    There ya have it...get 'er done...
    Pismo Beach, CA
    Dr.Ciao... it's Pete's Upholstery, in Grover Beach. If you are familiar with the area he's at 1085 Grand Avenue, across the street from Miner's Ace Hardware.
    He's been there for years and does great work.
    Lew Morris
    1963 Dnepr
    Astatula, FL
    Quote Originally Posted by BCKRIDER View Post
    What Doug describes is basically what I said. The zipper teeth have to align in 2 planes, side to side and front to back. Squeezing the slider closed regains the front to back alignment. Just don't squeeze it to the point it drags on the fabric portion of the zipper.
    For lube I used straight silicone spray, found in the auto parts store. I has less 'oil' to attract and grab dirt than WD-40.
    Bob Weis
    '04 K12RS - Hannigan Hack
    Mansfield,MA
    It may not make it as a sticky but I have added "tags" to make it easier to search in the future.
    I actually use a lot of products from the marine industry and marine supply such as West Marine. The other day when I was there I picked up a tube of Star Bright Snap and Zipper lubricant with white PTEF. This product works well on keeping a zipper moving. Hint-once applied let it set in the sun to allow it to melt in
    Another great hint!
    Mod Squad
    2009 F800GS 1994 TW200
