Results 1 to 15 of 23
Thread: Broken Zipper
    DrCiao
    Broken Zipper
    So, the zipper on my Reflect Leather Jacket isn't doing so well. You zip it up and the zipper splits. Anyone ever have a zipper replaced? Thoughts?
    Mansfield,MA
    Quote Originally Posted by DrCiao View Post
    Not familiar with the jacket but if you don't have someone locally that does alterations a good source for the service is the local drycleaner. Sometimes a cobbler with a more stout machine is needed for leather. Really not a bad fix.
    Mod Squad
    2009 F800GS 1994 TW200
    Registered User bmwgsrider's Avatar
    Amarillo, TX
    I got a zipper replaced on my riding pants by a leather shop.
    Ute's Chauffeur
    Sep 2006
    Central NY
    If you have trouble locally Rainy Pass does warranty work for BMW apparel, as well as, for individuals. http://www.rainypass.com/services.htm
    Mansfield,MA
    Quote Originally Posted by cruisincruzan View Post
    That looks like a good resource.
    Mod Squad
    Astatula, FL
    Zipper preventive maintenance & repair
    This is on my website from when I used to repair tankbags:
    Here is your chance to "do it yourself" following these simple directions. First it is important to clean and lubricate your tankbag zippers. They are full of the road grime that you routinely wash off of your bike. I use a silicon spray, apply liberally, wipe zipper with a clean rag, reapply and operate the slide. What a difference!
    You should also be aware that most, but not all BMW tankbags use locking tab zippers. To release the lock you pull out on the pull tab, perpendicular from the direction of the slide travel.
    If you have a zipper that seperates after being closed, you can often repair this by squeezing the slide together with a pair of pliers. You want to squeeze it just slightly, not to the point that the slide binds on the cloth portion of the zipper.
    Note: This method works on any zipper that is not too worn, including jackets, pants and Stitches. Lube your tent zippers too, nothing worse than a 2AM nature call and being unable to get out!
    Bob Weis
    '04 K12RS - Hannigan Hack
    Registered User WalterK75's Avatar
    Feb 2009
    Mississauga, Ontario
    Is there any chance you can send the jacket back to the manufacturer and get them to repair it? I did that with a pair of pants where the long leg zipper failed.
    DrCiao
    I asked the shop where I got the jacket and they said it was just out of warranty, so sending it to BMW wasn't going to happen. They had a local person they used for repairs, but as I live over an hour away, I kept the jacket for a safe and warm ride home.
    Pismo Beach, CA
    I'd take it to a local "canvas" shop. The guy down the street did the zippers on my sailing foulies and they turned out great. I think he charged $20 for the zippers and labor for the bibs, and the jacket.
    Lew Morris
    1973 R75/5 - original owner
    May 2007
    So. Cal.
    Yup, either a shoe repair place, they do more than shoes, like purses, etc. Or a good dry cleaner. Last year I had a jacket zipper replaced. I went to the fabric store and picked out one I liked, the same length as the one on my jacket. The teeth were much larger. I then took the jacket and the zipper to a dry cleaner that does alterations....and they replaced the zipper for about 25 bucks. Bargain! Jacket is as good as new.
    BTW, my zipper was doing the same thing as yours....those little teeth get worn out.
    __________________
    Nancy
    2013 R12RT, '07 F650GS (Sold), 09 R12RT, 2012 Yami FZ6R
    IBA# 529
    MOA,RA,ABC,NEF,MCPR,MOAL brownie's Avatar
    Oct 2003
    Pensacola, FL
    Talking Rainy Pass +1
    Have had VERY good repair work done @ Rainy Pass...nice peeps too!!
    Words to Ride by: Patience, Anticipate, Paranoia
    Shep Brown MOA 27510
    "Igor" 82 RS "Inga" 04RT
    Pensacola, Flairider
    DrCiao
    Are we doing metal or plastic zippers? Metal will scratch the paint?
    I found a local shop that wants $45 to do the zipper. That's not including the zipper itself.
    Pismo Beach, CA
    Plastic will scratch the paint too ... ask me how I know this.
    Lew Morris
    DrCiao
    Yikes, sorry to hear that.
    Registered User robsara's Avatar
    Dec 2009
    West Michigan
    Sometimes your slider gets out of whack. I'd take a long look at it, and a slider on a working item and see if you notice a difference in clearances etc. Sometimes a firm grip with a leatherman or needle nose and you are back in business. They can "loosen" if they get pulled or tweaked too hard.
    Maybe you did this already, and I'm insulting your intelligence. But if someone else looks here and is having this problem give it a shot.
    Rob
    Rob R
    1994 K75 My first bike.
