Results 1 to 6 of 6
Thread: Wiring harness/instrument cluster
    Registered User 88bmwjeff's Avatar
    Aug 2004
    Walnut Creek, CA
    So, I'm trying to solve my intermittent neutral light. Symptoms I've noticed: light flickers while bike idling, goes off and on (when it should be on), turning the handle bars can sometimes effect the light, and while moving the main wiring harness at the main plug at the instrument cluster ever so slightly-the neutral light goes on and off. I've determined that the harness is good with a digital multimeter (DMM). So, I bench tested the instrument cluster (with a spare motorcycle a battery and alligator clips) and determined the light socket/circuit board was not working properly. Since many people have complained about this weak link in the cluster, and my lack of time to find repair solution, I ordered a new one. The lights in the Instrument cluster work great now; however, I was not pleased to find my problem still persists. At first I was baffled--most likely due to my frustration that I hadn't solved problem. I double checked the wiring harness using a DMM and it checked out good again. I bench tested the instrument cluster, as I did previously, and it works fine. I double checked the bulb holders and sockets, and everything is good. I swapped bulbs from one without the problem and that did not help. So, this leads me to one probable cause, one of the female connectors in the main wiring harness plug is too big, but I can't quite figure out how to compress them slightly for a better fit. Too much and I may destroy the plug let alone possibly having trouble removing the plug. Anybody have a good suggestion here?
    Jeff in W.C.
    1988 R100 RT (the other woman)
    "I got my motorcycle jacket but I'm walking all the time." Joe Strummer
    Aug 2008
    North Carolina Coast
    Wiring Harness . . . .
    I think the plugs on the harness are female where they enter the cluster. I had a similar situation. The cluster connections are s/s and the harness are alum. The cluster recepticles are slit so they could be tightened up a little or there could be a broken solder connection. Make sure you lubricate the connections with dielectric grease. The harness is over $330. and a few hours to replace.
    Good Luck!
    Campbell Tellman II
    '93 R100RT
    '11 S1000RR
    Huckleberry, Gilera &Toad kstoo's Avatar
    Jul 2007
    Burlington WI
    Just remember that dielectric grease is non-conductive by the very nature of the name and, if you add too much in the wrong place, could actually make things worse. Still, it is great for getting plugs to seat properly and keep moisture out of connections.
    1980 R100T (Gilera), 1982 R100RT (Toad), 1975 R60/6 (cern?ícalo)
    Adventures at the Cave
    Rally Rat tvrla's Avatar
    Oct 2004
    Portland, Oregon
    Did you ever get this sorted out? Was it a break in the wiring harness under the steering head?
    Aug 2004
    Walnut Creek, CA
    Quote Originally Posted by tvrla View Post
    I posted a new thread on how I repaired it, but I didn't post an answer here. Sorry. It was the plug. The answer can be found here
    http://forums.bmwmoa.org/showthread....t=how+if+fixed
    Jeff in W.C.
    Oct 2004
    Portland, Oregon
    Interesting solution! I've replaced the plug with a good used one to handle a similar problem, but your idea seems much simpler. I like the idea of drilling a hole through to the back side - and silicone seal would probably be enough to seal and retain it.
