Results 16 to 22 of 22
Thread: Heated jacket liner
    Registered User lkniess's Avatar
    Jul 2010
    Beaverton, OR
    no you dont
    I have a Tormaster Synergy Jacket liner and G3 gloves. I simply plug the gloves into the jacket. The included Tourmaster controller allows you to control the temp of the combo at low, med and high. You cannot control the gloves and liner separately. The gloves come with the cabling to connect the gloves separately from the jacket if you chose. You would have to buy a Gerbing controller for the gloves to control the temp for them. Does this reply make sense??
    Proud Veteran SteveAikens's Avatar
    Clovis, NM
    WOODY
    It's certainly the preferred way to heat them but not really a requirement. All you need is the harness that comes with them to get from the controller [which you should have] or a switch to the gloves. The harness is simply a "Y" that let's you run a wire down each sleeve and then plugs right in.
    Nom de Plume:
    Steve Aikens, Clovis, NM
    BMW MOA #6218
    IBA# 442
    Dec 2009
    Charlotte, NC
    I see the harness (Y) you speak of. Thanks.
    Tour and Gerbings both seem to have good reviews for serving their purposes. IF you were to go with a system (or more than one item), it appears that the G is more seamless? But, more $$$.
    Jun 2007
    Portsmouth, NH
    I am very happy with my Gerbing liner and gloves. They only complaint I have is that the wires between the jacket and gloves are a bit stiff. Softer wire would make the surplus wire easier to deal with.
    If you have a place to rigidly mount the heat controller, that would be a good idea. I usually clip mine to a pocket or tank bag and that's not optimal.
    Clovis, NM
    Quote Originally Posted by woodrow823 View Post
    Compare warranties...
    Nom de Plume:
    BMW MOA #6218
    IBA# 442
    Dec 2009
    Charlotte, NC
    Warranty
    I checked them:
    Gerbing - Lifetime Warranty (on heating element)
    Tourmaster - Three years
    Clovis, NM
    I checked them:
    Exactly. However, Gerbings warranty includes wiring, not just the elements.
    Nom de Plume:
    BMW MOA #6218
    IBA# 442
