Results 1 to 15 of 17
Thread: RT needs new shoes....any advice.?
    leeinmemphis
    Hey everyone,
    After 20+ years of riding today I had my first flat on my '02 RT. I ran over something that made a pretty good sized hole in the rear tire so I need to replace it. I am going to be using the bike for commuting, long day/weekend trips. I am looking for recommendations on what tires everyone would suggest? I'ld like a fairly soft compound with good rain handling. I'ld like to get a least 7-8k out of a rear tire if possible. Any advice is greatly appreciated. Thanks.
    Feb 2006
    Long gone
    I've been very happy with Pilot Road 2's. '97 RT
    Ride Well
    Tiverton, RI
    +1 04 RT
    www.OceanStateBMWriders.com
    leeinmemphis
    I am currently running a 170/60/17 rear tire. The closest size appears to be 180/55/17. Any reason that wouldn't work?
    Sep 2007
    So. Calif.
    Lee - It looks to me like the Pilot Road 2 is available in the 170/60/17 size (according to Michelin's online fitment guide). I'm on my fourth set of PR2's and replace them at about 10K miles, and as far as I'm concerned they're unequalled for RT's. However, I've heard whispers that the PR3 will be here very soon - maybe they will be even better.
    '14 R1200GS,
    Priors: '13 K1600GT, '08 R1200RT, '04 R1150RT, '05 R1200GS, '73 R75/5.
    leeinmemphis
    Quote Originally Posted by Sailorlite View Post
    Thanks for the info!!! Michelin has the same size tire I am running but it also says the 180 will fit as well. I'll call cyclegear tomorrow to see if they have either of them in stock. I've been told that if you take your wheel in that they will mount/balance it for free.
    Yarddog
    Ummmmmmm....another tire thread...ummmmmm
    Sheboygan, WI
    Smile
    Quote Originally Posted by SIBUD View Post
    +1
    leeinmemphis
    I bought the Pilot Roads 2. The guy at cyclegear mounted/balanced it while I waited. I am planning on carrying the front to him in the morning. Thanks!!!!
    Clovis, NM
    Quote Originally Posted by Greenwald View Post
    +1
    Add me to the PR2. Good tire on my R12RT and was a good tire on my RT-P.
    Nom de Plume:
    Steve Aikens, Clovis, NM
    BMW MOA #6218
    IBA# 442
    look at
    The pirelli sport angels. I have them on an Rt1200 and a Multistrada.
    Touring Panpsychist Theo's Avatar
    Apr 2010
    Western MA
    FYI: Tire Calculations
    While the 180/55-17 should fit, it will have a slightly smaller circumference compared to the 170/60-17. This will cause about a 1% speedometer error:
    from the online tire size calculator
    This will result in a slightly higher speedometer reading than BMW's already +2-3 mph overstated speed.
    from the tire calculator
    Theo
    2009 R1200RT, 2007 Shadow Aero 750 (sold)
    2012 MINI Countryman S, 2004 MINI Cooper S JCW, 2000 BMW 328i
    Registered User boxwrench's Avatar
    Dec 2008
    Daytona Beach area,Florida
    Metz Z6 and dyna bead for me
    2000 R1100RT opal blue "Millenium Falcon"
    2006 Suzuki C50 Boulevard blue/silver w/ DJ drive mod.
    "Gator"
    Is there any downside going from a 170 to a 180?
    100,000+ miler 32232's Avatar
    Southwestern Ontario
    Quote Originally Posted by Zaasu View Post
    I'm not sure of the OEM size tire for your bike, but I always default to the manufacturer's recommendation. Back in the day I would want to go wider, because bigger must be better, right?
    Experience showed that wasn't necessarily the case, as the factory optimizes the handling of the bike for the recommended size tires. In Germany, it is illegal under the TUV regulations to run an incorrect size.
    The change contemplated above is a minor one and should have a minor effect on handling. Going to wider tires generally slows down the turn in when cornering. That said, the amount of difference in only going from a 170 to a 180 could be less than just changing to a tire with a different tread profile within the same size range. There shouldn't be a big difference.
    Dave
