Results 1 to 15 of 16
Thread: fuse blocks
    Jul 2007
    South Hero, VT
    fuse blocks
    Both "fuzeblock" and "centech" advertize in our magazine. any opinion as to which is better or are there any other recommended?
    Oct 2003
    They are somewhat different.
    The Centech controls a power input and distributes it to multiple fused circuits. If you want switched power (eg, turns on and off with the key) you have to supply a separate relay. I believe that the Centech can handle up to 30amps per circuit.
    The Fuzeblock comes with an integrated relay. By choosing which pair of clips you put an individual circuit's fuse into, you get direct or switched power. In this way it's more flexible than the Centech. However, the Fuzeblock can only handle 30amps total, through all of the circuits attached to it. (That's about 360 watts.)
    That might not be enough if you want to run two powerful driving lights and two full electric suits, all at once, for example. (Of course, if you have loads like this and you wanted the flexibility that a Fuzeblock affords, you could run two of them in parallel.)
    http://darryl.crafty-fox.com
    Jul 2007
    THE BIG SKY
    I have both mounted on different bikes; 2 Centecs and 3 Fuseblocks. As Darryl mentioned the Fuseblock has some limitations, but is an easier and neater install. The items that can normally exceed the Fuseblock's 10 amp per circuit or 30 amp total capacity are aux lites and heated gear. I've gotten around this by using LED lites that are well under the limit or in one case by establishing a separate fused circuit straight to the battery for the over 10 amp circuit.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    Registered User coalminer's Avatar
    Jul 2008
    St. Francisville, LA
    Can't say which is better but I installed the Centech that purchased from Excel Cycle Werkes. Comes complete (wiring, instructions) and ready to install...easy, easy, easy.
    palica
    Quote Originally Posted by DarrylRi View Post
    But then, the charging system (alternator) may be the limitation...
    IMO, the Centech is more of the "older" technology and it is perfect for me: easy to understand, easy to fix, easy to manage. Just the perfect match for an airhead.
    The Fuzeblock, IIRC, does not have fuses but internal relays... I have no idea what is going on in this box and do not want to know...
    Oct 2003
    Quote Originally Posted by palica View Post
    The Fuzeblock is very simple technology. It uses fuses, just as the Centech does. The difference is that each fuse can be inserted in one of two ways; one way supplies power direct from the battery; the other gets its power from an on board relay that is controlled by a switched power lead.
    This is the inside of a Fuzeblock. The input wires are on the left: brown and black are battery ground and power. The small red lead is switched power and controls the relay that is mounted just to the right. You can also see that the Fuzeblock has space to carry a couple spare fuses.
    In my case, I only installed one circuit for a Powerlet plug. (I have plans to add a couple more, later.) You can see the fuse for that on the far right. The black and red leads in that area go to the Powerlet plug. The way that 10amp fuse is installed makes the plug a switched power plug, but if it were installed into the two lower slots, it would make the plug hot all the time. Each of the 6 circuits can be individually chosen to be switched or always on.
    This pic is from my Fuzeblock installation on my R1200ST, and I took the switched power from the existing power plug (which is switched). On an Airhead, a suitable switched source is the taillight or parking light. The draw for this is very small. A Fuzeblock should be completely adequate to handle any power chores on an Airhead.
    100,000+ miler 32232's Avatar
    Southwestern Ontario
    Another alternative is from Eastern Beaver. I have no connection other than being a very satisfied customer. They have several power distribution setups designed to get around the "challenges" presented by canbus electrics. I particularly like that the fuse blocks are sealed with a watertight cover. If they don't make the exact configuration you want, they can do a custom unit.
    http://www.easternbeaver.com/Main/main.html
    Here's the setup on my F800ST:
    Dave
    Riding where it's hot! AZ-J's Avatar
    Mar 2007
    Scottsdale, AZ
    Dave, I have the same Eastern Beaver fuse lock on my bike, powering a Zumo 660 on and off with the key, and the inside components of a tank bag, hot all the time for compressor and such, but drawing no power when not in use. I connect much that way when the bike is use.
    My bike shown here
    Jordan M, MOA #24434
    My Blog
    Registered User TOMRUNNING's Avatar
    Greenville, Wisconsin
    accessories
    I have had the centech installed on two bikes and have had no problems. I ordered the units from Excel Cycle Werkes with their install and relay kits. Great company to order from. Just give them a call, I don't think they take internet orders. 309-244 7405. they attend most national rallys.
    Tom Running, 51141 Greenville, WI
    "Love is when you like something as much as your motorcylce." Sonny Barger in Hells Angels
    by Hunter S. Thompson 1966
    Touring Panpsychist Theo's Avatar
    Apr 2010
    Western MA
    +1 on the Eastern Beaver and the amazing quality of the unit (not to mention the customer support)!
    Theo
    2009 R1200RT, 2007 Shadow Aero 750 (sold)
    2012 MINI Countryman S, 2004 MINI Cooper S JCW, 2000 BMW 328i
    Thumbs up The beaver
    Leave it to Eastern Beaver...........
    support is a response email away....great product great support
    Apr 2010
    Western MA
    Quote Originally Posted by Tooth View Post
    Leave it to Eastern Beaver...........{snip}
    Yeah! No support haskells!
    Theo
    Jun 2007
    Portsmouth, NH
    Has anyone tried one of these? It seems to have a good feature set for an electrical connection device:
    http://www.aerostich.com/powerpak-po...ule-pdm60.html
    2-up and havin' fun sugarhillctd's Avatar
    Oct 2007
    Just above the Notch, NH
    Another very satisfied Eastern Beaver customer.
    Their site has a comparison between Centech and their Power Center- go to the bottom of this page: Power Center
    Also I have to highly recommend their headlight relays. If you have an older (pre-canbus?) BMW, the headlight wires are, let's say, inadequate. When I saw how thin the headlight wires were on my '93 K-RS, it was a no-brainer that they needed help, even with a stock wattage bulb.
    EB ships fast and Jim will make sure you get what you need. If you email him he will respond.
    John & Cathy
    '92 K100RS (gone- '04 R1100S Boxer Cup)
    SS1000, BBG
    Clovis, NM
    Fuzeblock here.
    Nom de Plume:
    Steve Aikens, Clovis, NM
    BMW MOA #6218
    IBA# 442
