Page 1 of 7 1 2 3 ... LastLast
Results 1 to 15 of 105
Thread: Tapatalk access
    100,000+ miler 32232's Avatar
    Southwestern Ontario
    Tapatalk access
    I can log in to this site on my iPhone using Safari, but when I try to log in through Tapatalk it won't accept my password.
    Tapatalk account login works for the other forums I belong to. Any ideas?
    Thanks,
    Dave
    '06 Triumph Scrambler (Trans-Labrador veteran)
    2 Wheeled Troubador oldhway's Avatar
    Nov 2005
    Idaho
    Tapatalk
    because of this sites security software it is not compatible. We have tried to make it work and have been unsuccessful.
    Steve Marquardt
    Thanks for the quick reply.
    Too bad as the Tapatalk interface works well otherwise. I'll use it for viewing and Safari for posting, if need be.
    Dave
    This post:
    http://forums.bmwmoa.org/showpost.ph...2&postcount=16
    seems to indicate one our plug-ins needs to be updated.
    looking for a coal mine knary's Avatar
    pdx
    It's our login system as required by secure services.
    The plugin is a month old or so.
    Registered User JohnM's Avatar
    Da Joisey Shore
    Just asking for confirmation that I can't access the forum via my Droid through Tapatalk.
    No problemo if I can't due to website security.
    Which way to the snacks? sumwon's Avatar
    Dec 2009
    Central IL
    Just putting in my $0.02 that it would be nice if logon worked especially sine this site claims to be compatible with Tapatalk and was one of the reasons I purchased Tapatalk. If you are not going to fix or cannot fix the issue, then you should disable the popup indicating compatibility.
    When/where do you see any popups? I've never seen one...I don't access the site via a smartphone, though. If such things do show up, then the office needs to hear about this.
    pdx
    done
    All-round Motorcyclist MarkM's Avatar
    Dec 2010
    St. Louis
    Quote Originally Posted by knary View Post
    done
    I'm not sure what "done" means, but I've been able to successfully use Tapatalk on my iPhone for the past few months. Problem solved, for me at least.
    Mark M, St. Louis, '13 R1200GS
    Registered User PaperBoy's Avatar
    Jun 2008
    Oroville, Washington, USA - 48.93472,-119.43833
    Tester Site Password worked for me
    All right, now I can log in. Thanks for the workaround.
    Registered User DPeakMD's Avatar
    Sep 2007
    Franklin, IN
    Quote Originally Posted by PaperBoy View Post
    This worked for me. Thanks MarkM.
    Dallas
    2011 R1200GS Adventure
    Smoke Grey Metallic Matt
    Dec 2009
    Central IL
    It works! Thanks a lot for helping to make this work.
    Registered User kihei7's Avatar
    Jun 2006
    Gilbert, AZ, USA
    Smile
    Using the process of logging onto forum first through Account Management, then clicking link for system gen password works! Finally back onto forum throught Tapatalk on my iPhone4 & my Kindle Fire. Wouldn't have solved it without forum discussion. Thanks!!
    John Sachs
    Pacific Blue 2002 R1150RS
    Citrus Green 2004 R1150R Rockster
    BMWMOA 45617 AMA 576082
